Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Stirred up dirt in tank. Now barely runs
Old 10-16-2008, 11:45 PM
92RS shearn's Avatar
I changed the fuel filter an in the process most of the fuel tank was drained. Today I just drove to the gas station and the car was running perfect.
I filled up started the car with no problems.
After I went to exit the station and the car stumbled and died. I managed to get it home after about 20 minutes (which is a litteral mile away) and I needed to restart the car over a dozen times.
I am pretty sure I stirred up a lot of crap at the bottom of the tank and that is why my car started running so poorly.
My question is what do I do now? Do I just need to let the crap settle? Replace the new fuel filter with another one? Drain the tank (which right now is completely full)?
92RS shearn is offline
Old 10-17-2008, 09:22 PM
Green96Z's Avatar
Make sure the lines on the filter are tight. You could be sucking air into the fuel system.
Green96Z is offline
Old 10-18-2008, 04:15 PM
The fuel pump is in the fuel tank. If the lines were loose it should be leaking gas not sucking air in I would think.
Old 10-18-2008, 07:08 PM
Green96Z's Avatar
You said filter, so I thought that's what you meant. Even so, the line connections for the pump are still outside the tank.
Green96Z is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Sergio
01-27-2016 04:27 PM
D1SC383LT4
01-26-2015 01:41 PM
k1996z28
01-21-2015 07:22 AM
ChrisFrez
12-15-2014 03:09 PM
Quick Reply: Stirred up dirt in tank. Now barely runs
