Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Starts had when hot
Old 07-30-2013, 10:18 AM
Huntmaster86's Avatar
Starts had when hot
I just got this 95 z28 with a reman lt1 with 6k on the new motor. Ca starts good when it's cold but when car is at temp or even after driving for a bit i starts hard. Has a new battery too. 700 cca. Anyone have any thoughts?
Huntmaster86 is offline
Old 07-30-2013, 03:38 PM
Re: Starts had when hot
When it warms up does it seem to be running rich? A problem with the coolant temp sensor (the one in the water pump housing, for the PCM) can cause difficult hot starts if it's not telling the PCM the engine is warmed up.
May also be a problem with the ignition control module (ICM) heat soaking.
Do you have the ability to scan it for codes or to data log the PCM?
Might be worth checking the fuel pressure at cold and hot starts.
Injuneer is offline
Old 07-31-2013, 03:43 PM
Ill get it scanned to see if there are any codes. Are the above issues easy to fix or are they pretty involved to get to the sensors? I haven't had the car long so I don't know my way around it yet.
On a side note it does have a bigger tb and a cold air installed. Should it be tuned at this point or would that come after other modifications?
10-31-2016 11:09 AM
meissen
06-01-2015 07:59 AM
mspennyhughes
03-01-2015 03:50 PM
Britbilly
01-07-2015 08:49 PM
Caps94ZODG
22
07-30-2002 08:45 AM
Quick Reply: Starts had when hot
