Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Pump for 36lbs injectors?
Old 05-17-2013, 09:20 AM
browenb's Avatar
Did a quick search at summit, Granatelli has two pumps..
Granatelli Motor Sports F-Body In-Tank Fuel Pumps GM722-340 - Mobile SummitRacing.com
Granatelli Motor Sports F-Body In-Tank Fuel Pumps GM722-2 - Mobile SummitRacing.com
Is it worth the extra 30 bucks for the first one? Or will the second one feed the injectors well enough?
It's on a 383 lt1 with 58mm tb setup...
Any other pump suggestions?
browenb is offline
Old 06-12-2013, 01:09 PM
evilchevy's Avatar
Re: Pump for 36lbs injectors?
I'm thinking your best bet is to call Granatelli up and see what they would do
I had there 255 LPH pump can support i think like 700 N/A and 545 F/I if i can remember
I had that pump on my f body and it worked great and i was at 500 with a supercharger
evilchevy is offline
10-31-2016 11:09 AM
onefastgta
03-19-2015 10:09 AM
T-REX
09-01-2002 02:28 PM
tbyrne
07-02-2002 05:37 PM
T-REX
05-14-2002 08:47 PM
Quick Reply: Pump for 36lbs injectors?
