Power for universal coil
Re: Power for universal coil
You probably want a "+12 Hot in run, test or start" line to feed the distributor. Since you will be pulling the old harness and PCM out the most reliable spot would be to get the +12 volts from the under hood fuse block. Fuses 9 & 10 7.5 amp each feed the injectors which you will no longer use. So you could get into the under hood panel and use one of then to feed the HEI. Or just pull a pink wire out of the injector harnesses left or right as it comes from the IP box fuses 9 or 10. Then when you remove the injector harness run the pink wire to the HEI.
Correct... Hot in run is with key on only, start is when car is cranking and test is when key is turned off to on to test indicators, line is not active with key in Accy mode. That is when you would want the distributor/ignition activated. I agree "Always Hot' is directly connected to the battery, via a fuse and you don't want that.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
