Need 60lb injectors WHICH ONES??!!!
Not sure just going by what the dyno tech told me. I thought the 42's would be good im only pushing approx 450 RWHP and he says I need 60lbs because once we go above 5,200 she goes pretty lean and he wants to add more fuel. So he was talking about the boost referance regulator and then he said I should just go with 60lb's
If you are driving them with the stock PCM, and no external converter, you have to use a high impedance injector. That sort of limits your choices. Look at the Racetronix website.
autoxr166
09-25-2015 04:21 PM
