losing fuel pressure under load
i have a 95 camaro thats losing alot of fuel pressure underload. its a 383 and im using the 255 walbro pump with an aeromotive regulator 36 lbs injectors. fuel filter is brand new. when the car primes it tacks just about 60 psi, running at idle about 42ish,if i rev it at idle it drops down to mid to high 30s. driving around the block it holds decent pressure. but as i go up quickly in rpms it drops down to 20ish or below. im scared to WOT it as may guess is that the needle will find 0 pretty fast. if someone could point mein the right direction as maybe i hooked something up wrong or maybe a faulty part? thanks
Re: losing fuel pressure under load
At this point it could be anything, the pump, the regulator, or leaky injectors. Check out "shbox" website he has a lot of info on how to check everything out on his how to's page.
4th Gen LT1 F-Body Tech Aids
Mike
Mike
The Aeromotive LT1 fuel pressure regulators are known for a high failure rate. The fact that it primes to 60psi is indicating a problem, if you didn't set the AFPR that high.
Do not attempt to take it to max load. At 20psi your 36#/HR injectors can only supply 24.4#/HR. It's going to run seriously lean.
What is the fuel pressure regulator set to? Is that the pressure you told the tuner you planned to run?
What are using to read the fuel pressure - a mechanical gauge or an electronic gauge with the sensor hooked to the Schrader valve?
when i set the pressure i started the car checked the pressure, shut the car off made adjustment, and continued to do this untili got the 42 at idle. as for the tuner i just told him what i was running and let him do his job, so i figured it would be the same psi but since your asking i guess i could be wrong
When you reattach the vacuum line, the pressure will drop proportional to intake manifold vacuum. With a stock cam you will typically see an 8psi drop. With a more aggressive cam you might only see a 4psi drop. When the engine is idling, if you suddenly open the throttle to rev it up, the pressure should increase, because the manifold vacuum will drop.
thanks for the help guys but i think i just found my problem or atleast most of my problem, i used to have 36lb injectors. over the winter i had ordered and installed new injectors and the new injectors are 42lb. i was getting fustrated with other parts of this build and wasnt even thinking about the change in injector size.
Henson071
05-04-2015 12:23 PM
Alex Barnes
01-24-2015 10:21 PM
F(ast)-body
02-26-2003 09:05 AM
