Breakdown at operating Temperatures
I have a 1997 body with a 1995 LT-1 true Z-28 engine with 66k miles on it. Had to replace the original optispark due to seal leaking and getting water in it. After about a year out of nowhere it runs horrible after it warms up. I have read other threads and most seem to point to the optispark at this point. I have replaced spark plug wires,coil, ignition mod, temperature sensor in heads and in the water pump, new spark plugs etc.
Re: Breakdown at operating Temperatures
Have you scanned it? "Warm" means its transitioned to closed loop. May be a problem with the O2 sensors, or possibly the fuel pump overheating.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
