Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition stuck, Key will not move
Old 09-28-2014, 11:23 AM
CameroKitten's Avatar
Question Ignition stuck, Key will not move
I have a 1984 z28 that we were working on, worked fine drove it home, next morning the key will go into the lock cylinder but will not move ( secondary note the switch for the trunk and door locks not working either ). Someone outside told me that maybe I have the Ignition " Locked out" . and that it is a security measure that the key and other will not move.
Reading in the forum as well said maybe a fried lock cylinder... any suggestions?
CameroKitten is offline
Old 09-29-2014, 04:51 PM
Re: Ignition stuck, Key will not move
Does your car have an automatic trans? The later year cars have a cable that prevents the key from being turned unless the trans shifter is in "park". Not sure if your 84 has the same setup.
Injuneer is offline
liamcg97
11-25-2019 05:55 PM
10-31-2016 11:09 AM
Heathen1
01-02-2016 04:27 PM
Dzmaro
01-25-2015 10:39 AM
tds1213
11-27-2014 12:55 PM
Quick Reply: Ignition stuck, Key will not move
