fuel tank spitting out gas
For about a month now my fuel tank has been spitting out gas from the gas cap and runs down the side of my car and smells like gas while driving. It only seems to do it when the gas tank is more than 1/2 full and it will happen at random times (esp when its really hot out)
what can i do to prevent it? i replaced my fuel filter and did an entire seafoam about 2 months ago if that might have caused something. i'm thinking the fuel tank pressure valve possibly?
also my fuel gauge has never worked haha
Re: fuel tank spitting out gas
Two possible causes - cap gasket has failed (it's a sealed, unvented cap), or you have excessive pressure in the tank, possibly due to a faulty EVAP system or faulty pressure/vacuum relief valve. Excessive pressure can also be caused by the fuel heating up, which can be related to a failing fuel pump.
Moving to "Fuel and Ignition" forum.....
There's a pressure control valve that releases fuel vapor to the canister, and that is up high, between the tank and the canister in the driver's rear fender:
Courtesy of Shoebox
http://shbox.com/1/evap_system.jpg
In the event the tank pressure is not vented through the EVAP system, there's a pressure/vacuum relief valve that prevents tank damage due to over-pressure:
Courtesy of Shoebox
I'll check on another forum. Someone tested his for both pressure and vacuum. But I don't remember the numbers.
But the vent valve is only intended to prevent damage to the tank, in the event the pressure control system fails, and pressure or vacuum becomes excedingly high. The question would be why isn't the tank venting through the EVAP canister?
Do you have an axcessive pressure release when you open the cap?
Deadbolt24
01-19-2015 01:29 PM
guionM
9
08-29-2002 01:48 PM
guionM
18
07-11-2002 01:45 AM
