Fuel Rail crossover tube O-ring Size '95 Z28
I don't know if anyone needs this info, but I thought I would post since it took me forever to find a size that works.
The GM kit for these orings has been discontinued, but here is a good replacement.
AS568-110 is the industry standard and the size seems to match up really well. Here are the specs - Nominal size Id 3/8, OD 9/16, CS 3/32. Actual size ID .362±.005, Cross-section .103±.003 (9.19±.13, 2.62±.08). Make sure they are viton for fuel resistance.
You can get a kit of o-rings from harbor Freight that has this size in it. About $10 -$15 bucks. 180 Piece Viton O-Ring Kit
Good luck!
Good luck!
07-04-2005 05:00 PM
