Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump prime comnector
Old 02-20-2017, 10:04 AM
Rivas08_02's Avatar
How do i get 12volts to my fuel pump prime connector to see if it works. Meaning can i jump it with my car battery? Thanks guys !!!!
Rivas08_02 is offline
Old 02-20-2017, 10:36 AM
Re: Fuel pump prime comnector
Yes. Run a length 12 or 14 ga wire from a terminal in the red plastic ”+" box near the battery, to the prime connector. Wouldn't hurt to put a 20-amp inline fuse in the circuit.
Injuneer is offline
Old 02-20-2017, 11:22 AM
Rivas08_02's Avatar
Thanks boss i appreciate the knowledge. Ill pick up a 12 gauge wire at my auto store. And iwill keep you posted on my progress.
Old 02-20-2017, 11:37 AM
Rivas08_02's Avatar
Old 02-20-2017, 03:57 PM
Rivas08_02's Avatar
UPDATE: i tried to jump the prime connector and still no power at the fuel pump. Connected the wire to the plastic red postive part right next to the battery. Then on the i put my wire through the plastic little plastic cover thats on the fuel pump prime connector ..and still no juice
Old 02-20-2017, 07:09 PM
Does the fuel level gauge in the dash work correctly?
Injuneer is offline
Old 02-20-2017, 10:32 PM
Rivas08_02's Avatar
Yes . The gauge is good. I went on and pulled put the fuel pump from the trunk. Just to find out my fuel tank is rusted from old fuel. I guess the guy lied to me saying the car has been sitting for 2 years. More like 10. I dropped the tank. And boy was that a pain in the A##.
Old 02-21-2017, 02:46 PM
gaedbo's Avatar
Instead of dropping the tank, you may want to consider this in case you have any more issues with the pump....
https://www.camaroz28.com/forums/fue...th-gen-619463/
I have done this along with many, many others. Saves a lot of time and work after it is done !
I cut my opening so I have access to the disconnect fittings, and used a 12" x 18" piece of sheetmetal for my cover.
Attached Thumbnails Fuel pump prime comnector-100_2886.jpg   Fuel pump prime comnector-100_2891.jpg   Fuel pump prime comnector-100_2889.jpg
gaedbo is offline
Old 02-22-2017, 07:56 AM
Rivas08_02's Avatar
I did cut the trap door out. Pulled the fuel pump out. Just to find out my fuel tank was full of rust and all kinds of gunky stuff in there. So thats why idropped the tank to get it cleaned out. I found a local muffler shop that will cut it open clean it out for me and weld it back together all for 100$.
Old 02-22-2017, 08:14 AM
gaedbo's Avatar
I guess I should have read your post more carefully.
Just for the heck of it I went to RockAuto website....They have a new fuel tank from Spectra #GM2799C or #10269093 for around $160 and roughly $15 more for shipping.
Those numbers are for a 1995 Z28
gaedbo is offline
Old 02-23-2017, 06:29 PM
Rivas08_02's Avatar
Ok thanks bud.. what do you think about delphi pumps or airtech are those any good
Old 02-23-2017, 07:27 PM
gaedbo's Avatar
You have a similar post in the Forum....LT1-Based Engine Tech Discussion Forum.
It is #15 under the Thread ...Hi I am a new member-LT1 problem.
Responses are at #18 and #19 in that thread.
gaedbo is offline
Old 02-27-2017, 07:54 PM
Rivas08_02's Avatar
Update: put a used tank in from the junk yard. Installed new fuel pump. Now the car starts right up. Thank you guys for all the help and knowledge.
Old 02-27-2017, 09:05 PM
gaedbo's Avatar
Glad everything worked out.
Just curious, what fuel pump did you end up with ?
gaedbo is offline
Old 02-27-2017, 09:16 PM
Rivas08_02's Avatar
Delphi
