Fuel Pressure Regulator.....Bad?
#17
Re: Fuel Pressure Regulator.....Bad?
Checked the injectors and I didn't see any leaking. I also took a look at the fuel pump lines in the tank and all were ok. I going tonight to pick up another FPR because the one I have now is less than 2 weeks old.Maybe I just got a bad FPR. If not,I'm just going to take it to my mechanic and let him deal with it.
#18
hmm, odd. The only 4 things that'd cause the pressure to drop immediately are, leaking fpr, leaking injectors, leaking feed line and the check valve. As long as the gauge is working properly.
#19
I have two gauges and both show the same thing. The pump is under warranty,so if its the culprit,then great. We will see after I relaxed the regulator later today.
#20
Just put another FPR on and it's still dropping pressure. When I do get it to start,here's the numbers...
1. Pump prime> 40 psi (either by key or jumper)
2. Idle> 32 psi
3. Rev the car> 40 psi
I'm not sure if there is a way to check to see if the check valve on the pump is bad or not.Are they?
2. Idle> 32 psi
#21
Honestly, if you've tested 2 different gauges, with same results, and you know the fpr and injectors aren't leaking. No leaks at the feed line for sure, all that it could be is the check valve. Nothing else would cause the pressure loss when the engine gets shut off. I know you can test other pumps check valves by taking it out and blowing air through it to see if it blows out the other end, which if it does its bad.
I've never tried to test one on the lt1. I've just replaced the pump if everything else checked out and all that was left was the check valve.
#22
#23
#24
Got an email that a replacement pump was sent out Friday and he said I should have it on Monday. I was expecting to have to send the old one back first. Anyways,all the problems with the fuel pressure,got me thinking about getting a gauge pod and putting a fuel pressure gauge in it to keeps an eye on it.Would keep from having to keep connecting my fuel pressure gauge to the valve. I was looking at these,unless someone has better alternatives.Seems like they have all the necessary wiring,sender,etc.
Gauge 1
Gauge 2
Then I would just need a single gauge pillar pod.
Gauge 1
Gauge 2
#25
Why not buy a quality product, like one from AutoMeter? Who knows which third world country "Glow Shift" buys their stuff from? Mine's been going strong for 11 years.
http://www.injuneer.com/images/photo...r/DCP02679.jpg
#27
Installed the new pump today and the pressure doesn't drop drastically like before,it's still dropping though. I am getting around 34-36psi and 40 psi at WOT. It's a gradual drop down to around 18-20 psi after 20 minutes. I still don't think it's right? Could I just have missed a leaky injector when I checked? Car is running strong and is firing right up for now.Just wondering what's in store for tomorrow morning.
#28
Went back to make sure the injectors were not leaking and they are not.I put paper underneath all of them to be sure,paper was dry. I decided to turn the fuel rail screws another turn just to make sure the seals are seated. I start the car and the pressure is reading 42psi.Maybe the seals were not sealing all the way until I turned them another turn.It was holding at 38psi with the engine off and I'm going to check it again in about 30-45mins to see where it's at.I'll feel stupid if that's what it is,but I sure will be glad at the same time.
