Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel or electrical problem
Old 10-07-2014, 08:51 AM
tomfric's Avatar
I have a 93 z-28 lt-1 6 speed, going down highway car shuts off still have dash lights ect. sometimes will restart sometimes crank away, brand new fuel pump assembly and relay. very confused the problem happens almost exactly same distance from my house about 7 miles at 50mph. thanks for your thoughts. opti spark was changed out recently also
tomfric is offline
Old 10-07-2014, 05:23 PM
Re: fuel or electrical problem
Did you have the same problem BEFORE the Opti change? What brand Opti did you install?
Did you have the same problem BEFORE the fuel pump/relay replacements?
SES light come on? Have you scanned it for codes - there are a couple of fatal codes (Opti cam position sensor and ICM) that do not turn on the SES light.
Injuneer is offline
Old 10-09-2014, 07:46 AM
tomfric's Avatar
I had the same problem before relay, same problem before pump assembly, not shootng any codes. all I am doing is spending time and money, not sure what opti-spark it was my/sons car and he paid for that part. not sure what the ses light is, how would I detect the opti-cam sensor thank you so much for your help Tom
tomfric is offline
Old 10-09-2014, 08:06 AM
Check for codes, even if the SES light is not on. As noted, the two that could produce that result do not turn on the light.
You might want to have a shop test the ignition control module. They do suffer from heat soak with the location on the head. When the shop tests it, they have to make sure they get it up toward the normal operating temperature.
The other heat soak issue is the optical cam position sensor module in the Opti, but if that was experiencing intermittent problems, it would still set DTC 16 and/or DTC 36 for loss of the required pulse signal from the module.
Injuneer is offline
Old 10-09-2014, 03:05 PM
tomfric's Avatar
thank you see what I can do when I get out of work.
tomfric is offline
Old 10-10-2014, 04:30 PM
tomfric's Avatar
just played with it iced icm down and starts i think a big wahooo is in order go get part tomorrow and see what happens,thank you so much
tomfric is offline
Old 10-10-2014, 06:11 PM
Good luck!
Injuneer is offline
Old 10-16-2014, 07:17 PM
tomfric's Avatar
okay my wits end just came back "on the hook" again any suggestions same exact problem. except made it to work and died on my way home. thanks for thoughts
tomfric is offline
Old 10-16-2014, 07:53 PM
Missed the basic part of your second post. SES = service engine soon light. When it stays on it indicates that the diagnostic system in the computer (ECM) detected a problem with the engine. All you need to do is short a couple pins in the diagnostic port (connector under dash by your right knee), and the ECM will "flash" the code on the SES light. I'm on a phone right now, but I can post a link to the instructions.
The two codes that will shut down the engine, for the Opti and the ICM, do not turn on the SES. That's why you need to scan it even if the SES light isn't on. The Opti will set DTC 16 and 36. ICM will set DTC 41 or 42.
Injuneer is offline
Old 10-17-2014, 07:22 PM
tomfric's Avatar
thank you if you can post the link I will do it tomorrow I had another long day of law enforcement thanks again
tomfric is offline
Old 10-18-2014, 10:17 AM
Courtesy of Shoebox:
How to pull codes on a 93:
http://shbox.com/1/dlc2.jpg
Code definitions:
http://shbox.com/1/Dtcs.htm
Note that 1993 is unique in many ways, including some of the codes. Look at the column on the far right for 93 differences.
Injuneer is offline
Old 11-03-2014, 09:03 AM
tomfric's Avatar
hey just a quick update, was finally able to put on a friends computer and no codes, seems to be pointing at an opti-spark failure, if any body has a good 1 that can be given some sort of a guarantee. I would like to see what you have thanks
tomfric is offline
liamcg97
11-25-2019 05:55 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Moshbmx1
02-17-2015 10:51 AM
97z28k&N
01-09-2015 04:58 AM
Quick Reply: fuel or electrical problem
