Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Which wires should be hot on the fuel pump relay?
Old 09-01-2010, 09:14 PM
450hplt1's Avatar
I put a 94 pcm in a 97 camaro z28 and everything has worked so far but I'm having trouble with the fuel pump. I know its good because I hooked a battery up to it directly but now im trying to figure out which wires should be hot at the relay. The only hot wire I have is orange but I'm thinking I should have another one. Please help I want to get this thing on the road!
450hplt1 is offline
Old 09-01-2010, 10:09 PM
Nope.
Orange- +12v (should be hot all the time)
Red- to fuel pump prime connector by pcm
Drk Grn/White- fuel pump relay control from pcm (should be hot for 2 seconds when key is turned ON and hot when engine is running)
Grey- +12v to fuel pump (hot when relay is operated)
Blk/White- ground
shoebox is offline
Old 09-02-2010, 07:52 AM
450hplt1's Avatar
Ok thanks so much. I definately had my key turned on for longer than 2 sec so that is probably my problem but what if I still don't get power to it? Does that mean the pcm is bad and if so can I wire a switch for the pump? Thanks.
450hplt1 is offline
Old 09-02-2010, 10:24 AM
The relay control wire from the PCM gets voltage for about 2 seconds when the key is turned to ON. If the engine is not started (the PCM does not see ignition pulses), the PCM shuts it off. If you get nothing at either of those times, check the integrity of the wire from the relay to the PCM.
shoebox is offline
Old 09-02-2010, 11:20 AM
450hplt1's Avatar
This may be a stupid question but what exactly do you mean by checking the integrity from the relay to pcm? Do you mean follow it all the way to the pcm and check for power there? There are several green wires going into the different connections on the pcm so does anyone know which one is for the fuel pump? Thanks.
450hplt1 is offline
Old 09-02-2010, 01:14 PM
Use a meter to test the wire.
PCM connector C1 (red), pin 7 > C220, cavity J > f/p relay
All this info is on my Tech Page.
shoebox is offline
10-31-2016 11:09 AM
97Z28Muscle
02-06-2015 10:44 PM
RiverMutant96
01-30-2015 09:21 AM
ANDYZ28
12-29-2014 09:13 PM
Skull Leader
08-10-2002 11:01 AM
Quick Reply: Which wires should be hot on the fuel pump relay?
