Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
access door cutout for fuel pump
Old 04-13-2010, 11:13 PM
redz28camaro's Avatar
Arrow access door cutout for fuel pump
what tool is the easiest to use for cutting the access door for the fuel pump?
ive heard of tin snips is that a easy task?
i have a 97 camaro z28.
thank you.
redz28camaro is offline
Old 01-03-2013, 12:13 PM
TRIXSTA's Avatar
Re: access door cutout for fuel pump
I use a grinder like tool on my 98 took about 30 mins
TRIXSTA is offline
Old 01-07-2013, 07:45 PM
mzgp5x's Avatar
I did this mod on my 97ss. Used a grinder cut-off wheel (0.032" thk). Cut just inside the rear floor pan supports. Don't cut very deep due to tank and fuel line runs in these areas.
Take time and move slow.
B.
mzgp5x is offline
Old 01-16-2013, 10:40 PM
wildberryeagle's Avatar
I used a grinder to start the line and then I used tin snips. I started thinking about the gas tank maybe leaking and didn't want to risk the sparks on the tank. Only took about 30 minutes, just remember to cut towards the back seat pretty far to access the fuel line connections.
wildberryeagle is offline
Old 01-17-2013, 07:56 AM
Chet1185's Avatar
I used a dremel and it was very easy. the tank is like 1 1/2 inches below , i didnt even get close to it. I cut the sides and 1 across so i could just bend the flap back down and reattach it.
Chet1185 is offline
Old 01-29-2013, 04:43 PM
Ultra_Z's Avatar
i use painters tape then make an outline on the bucket... then draw a line in marker to follow use a RULER!!! I use my ryobi battery operated circular saw with a grinder wheel in it. i cut my bucket and swapped pumps in about 15 min!
Ultra_Z is offline
cmyname1
02-19-2015 08:38 PM
Scottyboy
02-11-2015 10:28 PM
RiverMutant96
01-30-2015 09:21 AM
ANDYZ28
12-29-2014 09:13 PM
Skull Leader
08-10-2002 11:01 AM
Quick Reply: access door cutout for fuel pump
