Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
89 Camaro running rich, dies when I stop
Old 01-27-2013, 11:08 AM
JosaiahIroc89's Avatar
My 89 Camaro is running rich, leaving black soot when I run it in idle and rev the engine. I have replaces the throttle sensor, oxygen sensor, idle sensor, charcoal canister, spark plugs (which were black with soot) and wires and rotary cap, spark timing module, and knock sensor. Even after all of that it is running rougher than ever and is still running rich. Now it even wants to die when I it's in drive when I stop. I have to hold the gas pedal down a little to keep the RPMs high enough to keep it running. This started after I changed the spark plugs. any ideas?
JosaiahIroc89 is offline
Old 01-27-2013, 11:19 AM
Re: 89 Camaro running rich, dies when I stop
Have you scanned it for codes?
Sounds like you may have a faulty coolant temp sensor, reporting too low a coolant temp, causing the ECM to run the engine in "cold start enrichment" mode.
Injuneer is offline
Scottylt1
01-08-2015 02:48 PM
Hurin
12-13-2014 07:38 PM
Scottylt1
12-04-2014 12:31 PM
nophix
11-30-2014 10:26 PM
Ricardo
11-29-2014 10:58 AM
Quick Reply: 89 Camaro running rich, dies when I stop
