What will you be doing to your FI Camaro over the winter?
Old 10-31-2012, 05:48 AM
DirtyDaveW's Avatar
As for me...
  • Cut trap door and install Aeromotive 340lph fuel pump.
  • Remove log manifold hotside and install new tubular hotside w/downpipe exit on passenger side.
  • Remove TC76 Turbonetics turbo and install PT76GTS turbo.
  • Get some nicks and chips in the paint fixed.
How about you guys?
Dave
DirtyDaveW is offline
Old 11-01-2012, 12:55 PM
mzgp5x's Avatar
Re: What will you be doing to your FI Camaro over the winter?
app...97ss 383 - D1 MM6
F1A Procharger.
New long tube headers and exhaust.
New starter circuit.
Nw custom fab torque-arm mount by me.
mzgp5x is offline
Old 11-01-2012, 09:40 PM
DirtyDaveW's Avatar
Sounds good. What are you doing for injectors, ignition and tuning?
F1A Procharger.
Old 11-02-2012, 03:23 PM
mzgp5x's Avatar
Injectors... Semens 72# peak and hold (running now)
Ignition... MSD_6a, MSD variable timing control unit, MSD 8202 coil, MSD wires, Zex plugs,
And (not popular with the members) Opti by All Ignition.com HiPerf unit. I also modified the check valve on the opti vent since the stock does not cut it.
Tune... By me. LT1_edit version 2.2. Been using for 10 years now on OBD2 PCM. I'm getting good @ it. Yes, I tried mail order (pcmfor less), did not work. A big mistake by me.
Also... Motown single plane, custom TB mount and duct (you may like it), Crank diven vac pump (really seals the cylinder rings). Moved BeCool Rad forward and run 7psi poly_Glycol media (great for FI apps). I re-engineered my bypass valves to work for my combination.
And more. A rolling experiment. I'm thinking that the 5.4:1 step_up ratio will help alot.
I have a photobucket acct. Look up my handle for pics... mzgp5x.
mzgp5x is offline
Old 11-02-2012, 09:39 PM
97WS6SCharged's Avatar
24x conversion and put the nose back on the car.
97WS6SCharged is offline
Old 11-06-2012, 04:33 PM
ShownomercyZ28's Avatar
Put all the pieces together and hope it does stuff.
ShownomercyZ28 is offline
Old 11-06-2012, 07:12 PM
Kevin Blown 95 TA's Avatar
It'll do 'stuff' one way or another. Put it together right and it'll do better stuff than if you put it together wrong.
Kevin Blown 95 TA is offline
Old 11-06-2012, 09:46 PM
Too many things that are not OEM anymore, hell I think the block is bout the only OEM part going back in
If it cranks, I will be happy
Old 11-08-2012, 06:53 AM
DirtyDaveW's Avatar
This is why I could never sell my car to a 'civilian'(ie: someone that doesn't know HiPerformance LT1).
  • Rear end: Ford 8.8 centersection, GM 10 bolts legs, different lugs than the front
  • Front end: LS1 spindles, rotors, pads, calipers
  • SPEC stage 4 clutch
  • SPEC billet steel flywheel
  • TFS heads, gasket plugs
  • 1.6 Ultra promag 7/16 rockers
  • LTCC LS1 Coil Near plug ignition
  • OBDI PCM
  • Turbo exhaust
  • Reduced diameter harmonic Balancer
  • Relocated O2 sensors
I just imagine the unknowledgeable new owner going to Autozone and just thinking they could order stock replacment parts for the above and the frustration they would suffer.
The snows are starting here so I doubt I'll be able to make too much headway on mine till next years Spring.
Normally, it would give me time to send the new hotside to the coaters but I want to install it in the car first to make sure nothing interferes. Jon mocked up everything on his mule motor and cross member but you never know how everything will fit on YOUR car till you put it on.
Old 11-09-2012, 09:01 PM
Reminds me of the last time I had an oil change done on my car that I didn't do myself.
Them: "Sir, your air filter is pretty dirty, we recommend letting us change it for you today."
Me: "Really? Bring it here and let me have a look."
30 min later "We can't find your air filter."
The manager wasn't too happy when I confronted him about that one.
Old 11-25-2012, 09:22 PM
Anybody making any progress? I ordered new fans and a shroud as well as a new AC condenser today. Also refabed most of my intake pipes to tuck up closer to the engine.
Old 11-26-2012, 11:50 AM
DirtyDaveW's Avatar
Not having a garage and us getting our first bits of snows, I'm afraid my progress will be slow for the time being. I want to test fit my new hotside in case I have to make any alterations before I send the piping to the coaters.
I've had a Walbro 255lph pump for about 2 years, never installed it. But now I see the Aeromotive 340lph, I'm going to buy that.
I was able to do a little more tuning on my SD 2 bar tune. The car really likes the tune and in this cool air, she's running fantastic.
Old 11-26-2012, 07:00 PM
That's pretty funny, Chris!
One day, I drove around back of a dealership looking for the parts department, and about half of the mechanics heard the car and piled out of the shop to look at it. They were real car guys in the best sense of the meaning - at least two of them got on their backs and shimmied under there to look at all the stuff I did underneath while asking me questions. Pretty unusual for a dealership .
My car needs the whole intake redone and also the discharge piping. I don't have an intercooler, but rely on the methanol injection, which seems to do the job. I need to get some tubing and fab it all up, and when I'm done with that, I might need to rethink my exhaust. Even though it will do a John Force burnout from a 65 mph roll, I still think I'm leaving a lot of power on the table. Not sure how much, if anything, I'll get done this winter though since I hate the cold. Maybe gather the parts and buy a tig welder.
Old 11-26-2012, 11:07 PM
You could always install an electric cutout about 6 inches after the exhaust housing and not worry about it.
Old 11-27-2012, 01:16 AM
lymlyt96's Avatar
dick harrell wide quarter panels
new paint scheme
new interior design
pulley down and put together my wastegate setup
finish the 24x conversion
put on new 18" bmw style wheels
lymlyt96 is offline
Quick Reply: What will you be doing to your FI Camaro over the winter?
