upgrade options for current p1sc? (doing a 383 build)
Doing a 383 rebuild on my Camaro. I have a p1sc single intercooler procharger now. Any suggestions on what I can do since its out of the car? what are the stage 2 options people are referring to? is it a 2nd intercooler? my single one is mounted on the bottom of the car.
Not sure if I want to upgrade to D1, but any options on the intercooler?
Re: upgrade options for current p1sc? (doing a 383 build)
You could go with a bigger intercooler and put it up front in the nose. Would require you to trim the plastic and remove the crash padding but it will increase the airflow by leaps and bounds. Or run an air to water setup. And there's always meth.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
