Suggestions
Old 10-23-2016, 09:55 AM
onetransam4u2nv's Avatar
Suggestions
I'm currently building a new engine and need some advice on valve train. So my short block is a lt1 4 bolt corvette block with eagle 4340 3.75 crank eagle forged 5.7 rods je forged piston 2 valve reliefs -.5cc. The heads are 190 afr's ported to 212's. 62 cc chambers, Manley 2.06, 1.60 comp 987 springs,titanium retainers 10 degree locks and 4808 guidplates with 7/16 studs. I have a vortex v-2 supercharger from my old engine I plan on using for about 7- 10 pounds of boost. If calculations are correct this should be around 10 5:1 compression. My questions are what's a good off the shelf cam to run on this set up? What's a good set of 1.6 roller rockets? And last question timing set and oil pump recommendations.thanks for any help
onetransam4u2nv is offline
Old 10-23-2016, 10:38 AM
Re: Suggestions
Since this involves running an S/C on a high compression setup, I'll move this to "Forced Induction" where you may be more likely to get a good response. You will have to be patient, because the responses there sometimes take a while.
Have you read the "sticky" thread on that forum "Forced Induction and the LT1"?
Injuneer is online now
Old 10-23-2016, 10:41 AM
Re: Suggestions
When I first put the s/c on I should look it over again. Thank ou
