Signs Of Supercharger Belt Slippage ??
#16
Re: Signs Of Supercharger Belt Slippage ??
It's cool to see a couple different threads pop up between here and the other message boards from Vortech YSi LT1 users. Also cool that the OP returned to tell a success story and describe what his solution was.
I'm surprised you're getting away without a modified bracket being added to your stock bracket. I was going to ask you the same question as Purple Poncho. The few others running the YSi seem to run additional brackets. I don't know if it is worth the trouble to go this YSi route. Shosovr, are you not having flex or belt issues w/o an added brace?
#18
"ponyackn" to date, I have not had any issues with my YSI. No flexing that I am aware of, and no issues with the belt. I did not think that it was any trouble at all ... other than it being a tighter fit. The mounting brackets seemed sturdy enough and it uses some pretty hefty bolts. The only issue that I had was when I upgraded to a 10-rib set-up, and trying to locate a belt that fits.
"95maroboi" my Camaro was making about 18 lbs @ 5700. I was told that YSI's will continue to make boost as you continue to increase the RPM's, but 5700 rpm was plenty for me.
#19
18 pounds, yeah belt slip must not be an issue!! I'm so tempted to go this route, but would likely attempt to fab a bracket. Don't see myself being as lucky
Your 10 rib clears the fan motor of the radiator?
Edit: I see your pulley sizes were posted. Man, even more amazing you don't experience slip.
#20
The 10-rib required a longer bolt for the S/C pulley, so now the head of that bolt sits in between one of the louvers (or shroud) on the back of the radiator fan. I remember thinking that a 12-rib would require some modification (trimming) to the shroud.
