Rings - Gapless Top vs Gapless 2nd?
Ok so heres my situation:
Currently have a d1 progarger on a stock internals LT1. This summer im looking at collecting parts towards a build next winter, for forged rods/pistons 355 to run on sub 10psi.
My question is in regards to rings. Im looking at Total seal piston rings on CNC motorsports, and it seems that there are gapless top and gapless 2nd ring sets of the TNT series. Both say they are for boost, however there is about a 60$ price point difference.
Im curious as to the reasoning for this, and what your guys thoughts are towards adequate rings. What would you suggest I use, keeping in mind the boost may come up down the road?
Re: Rings - Gapless Top vs Gapless 2nd?
Are the pistons engineered to use gapless rings? Do they have Vertical or Horizontal gas ports? Pressure equalizer groove? Is the car only a track car 98% of the time? If you answered yes to most of those, gapless is OK, if no, stay away from gapless.
I'm a Motörhead and I approve this posting....using Tapatalk 2.
the top ring is your compression ring the second rings primary job is to scrap oil from the cyl wall. when gasses get past the top ring it starts building psi between the rings. then the second ring looses control and starts letting oil past. then kaboom. and you want a wider gap on the second ring to insure it does not happen. so you can imagine how much trouble a gapless 2 ring could cause.
So with that in mind, would you rather a gapless top, or a conventional gapped setup?
Say totalseal gapless top vs totalseal classic AP for a street driven/weekend track car with mild boost (7-12psi?)
carguyshu
01-22-2017 11:19 AM
stockssn2o
05-25-2015 08:54 AM
