Procharger pulley size to make 8psi on a 383
Finally got the Golen built for S/C 383 and M6 sorted out.
My Powerdyne makes about 4.5 psi now with the 9 lb pulley and it doesn't sound like much until you take the belt off and see the difference.
Still very sweet.
In anticipation of this I bought a Procharger D1-SC kit with tensioner off a member here which he said was set up to put out 14 psi on a 383.
The pulley sizes are just under 8 inches for the crank pulley and just under 4 inches on the procharger head.
I don't want to run 14 psi boost right away and pulley it down to 8 psi intercooled.
Does anyone know what pulley size(s) I need to run to get 8 psi on a 383?
Still very sweet.
10-31-2016 11:09 AM
