LT1 Vortech oil drain question
Old 07-06-2012, 02:44 PM
LT1inaMGB's Avatar
I picked up a C4 Vortech kit for an LT1 with a reverse rotation blower on the passenger side and the instructions say to run the drain to the driver's side and put the pan fitting there. It would be much easier in my installation to drop it straight down and tap into the passenger side of the pan providing a much shorter and steeper angle for the drain hose. Is there anything wrong with putting the fitting on the passenger side of the pan as long as none of the rotating bits hit it? Windage issues, etc? I would probably place it in line with one of the main caps.
LT1inaMGB is offline
Old 07-07-2012, 12:29 AM
97WS6SCharged's Avatar
Re: LT1 Vortech oil drain question
Should be fine as long as it's above the oil level.
97WS6SCharged is offline
onefastgta
03-19-2015 10:10 AM
NorthPoleDev
12-31-2014 03:20 PM
pologreen97z
12-02-2014 10:42 AM
07-04-2005 05:00 PM
Brent94Z
03-21-2002 04:44 PM
Quick Reply: LT1 Vortech oil drain question
