Idler Pulley - Locked
Idler pulley locked up.....Looking for some advice/information.
Is this a standard pulley I can pick up locally, or is this an ATI part only??
My system is a P600
Thanks!!
My system is a P600
Thanks!!
Re: Idler Pulley - Locked
Solved!!!!.... Was able to remove the old bearings. They were a bitch to get out, but heating the pulley solved that. Picked up the new bearings from O'Rielly's for $12.00..... Much cheaper than buying a new puller from ATI!!
BTW..... the new bearings fit with no issues, so I will assume the bad bearings had something to do with the difficulties in the removal. I'm sure they got hot as hell.
sure can.... sorry I did not include that!!
The stock bearings - FAFNIR - # 203VV (two of them)
New bearings from O'Rielly's - National - # 203-FF (you will need two of them)
Thanks!!
Thanks!!
Aaront810
08-29-2020 09:34 PM
z28cam1993
09-09-2015 04:08 AM
