hotcam vs. blowercam on supercharged ltx
Old 11-26-2011, 01:16 PM
dizwiz24's Avatar
Just curious is a blower cam would provide that much benefit vs. hotcam (what I currently have installed).
The specs dont look a whole lot different:
Hotcam:
218/228 @ .050
.525/.525 (w/ 1.6 roller rockers)
112 LSA
Blowercam:
224/236 @ .050
.575ish / .585 ish (w/ 1.6 roller rockers)
114 LSA
This would be on a stock mildly ported head, 1 3/4" long tube, stock bottom end lt1 pushing 11 psi boost from a p600b and water/meth injection.
dizwiz24 is offline
Old 12-01-2011, 06:59 AM
David94TA's Avatar
Re: hotcam vs. blowercam on supercharged ltx
I went from a CC 305 on a 112 lsa to a cam similar to your blower cam example and picked up 43 rwhp. That was with only 6 lb of boost.
David94TA is offline
Old 12-01-2011, 07:35 AM
West South Central Moderator
AdioSS's Avatar
Go ahead & build it up with the blower, headers, etc & see how you like it before swapping camshafts.
AdioSS is offline
Old 12-01-2011, 07:45 AM
dizwiz24's Avatar
43 rwhp is a lot of power to pick up.
Did you go from a stock cam to a blower cam?
or some non-stock cam (such as hotcam) to a blower cam?
If you went from say a hot cam to that cam and picked up 43 rwhp, then yes Im probably going to run out and swap cams.
Are you on a stock-bottom end?
The one thing I fear is if I go to a cam that makes more power w/ blower, that it is going to be more likely to detonate.
Right now, everything is working fine and Im not getting detonation.
dizwiz24 is offline
Old 12-01-2011, 10:49 AM
Purple Poncho's Avatar
He wrote he had a CC305 which is a 220-230 w/ .544 lift before the blower cam. So a little larger then a Hotcam.
Purple Poncho is offline
Old 12-01-2011, 11:12 AM
David94TA's Avatar
Correct.
I have had all forged internals from the first build.
I think most people will tell you that 11 lbs of boost on a stock bottom end is risky.
Old 12-01-2011, 04:43 PM
dizwiz24's Avatar
Correct.
I agree, but would about with meth/water injection. Also dont forget GM motors have knock control (unlike Ford's).
I even have a fail-safe rigged such that it wont boost if the meth system 'faults' (ie. loses pressure).
dizwiz24 is offline
Old 12-01-2011, 11:55 PM
97WS6SCharged's Avatar
I think you're giving the knock circuit on these cars a little too much credit.
97WS6SCharged is offline
Hal Fisher
09-30-2015 09:03 PM
HAWG
09-25-2015 11:41 AM
MDZ28
11
09-24-2015 09:15 AM
DelSoto
09-19-2015 05:31 AM
Quick Reply: hotcam vs. blowercam on supercharged ltx
