Forced induction tuning question
Old 04-08-2013, 09:29 PM
David94TA's Avatar
Do you guys modify the %TPS for WOT table so that the PCM goes into power enrichment sooner? If so, what values do you change and to what? Thanks.
David94TA is offline
Old 04-11-2013, 05:22 PM
Kevin Blown 95 TA's Avatar
Re: Forced induction tuning question
I did change the under 4k part of that table to lower values, mostly because I have a 58 mm throttle body, so it makes more power at less throttle angle than if it had the stock 48. You need to consider when you are in boost, but still at part throttle, then figure out when/if you need to go into open loop and add fuel. You do this by logging a couple runs onto the interstate or do a couple roll ons. The way the table is stock, you would still be covered if you floored it, but it's just the odd case of part throttle and boost that you have to make sure that it gives you the fuel you need. Lower them too much and you'll just waste fuel. My values won't be correct for your application, so I can't help you there.
Kevin Blown 95 TA is offline
Old 04-11-2013, 08:06 PM
David94TA's Avatar
OK, thanks
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
CARiD
01-27-2015 06:27 AM
ChrisFrez
01-18-2015 08:05 AM
Quick Reply: Forced induction tuning question
