Fabbing headers... what gauge tubing?
Location: I reached back like a pimp and smacked that LS1....
Originally posted by sleeperz28
16 is good for the headers. I use 14 on the rest of the exhaust.
Curious why you made the rest of the exhaust thicker than the headers?
Sorta OT, but what's the advantages of 321 vs. 304? I'd assume 321 is a little stronger than 304 since you're running a thinner wall on the 321. Just curious. I'm planning on running 304 throughout, but haven't decided on a thickness.
321 is a titanium alloy. It will retain its strength at extreme temperatures moreso than 304 or 409. I wanted the header and collectors to be 321 because they'll hold up better when the EGT gauge passes the 1700 mark, and I wanted them polished and the 304 will dull down faster when exposed to high EGTs. You'll be fine however with the 304, 16 gauge.
You can get away with using mild steel, but if you go stainless you can get away without a thermocoating because the stainless will radiate half the heat of the mild steel.
carguyshu
01-22-2017 11:19 AM
99TransAmWS6
02-12-2015 07:23 PM
12-01-2014 08:08 AM
