BOV question
Old 03-19-2015, 01:55 PM
87Aerocoupe's Avatar
BOV question
Hey guys I'm getting a D1SC for my 97 SS and I want to know if I can use a 50mm BOV designed for use on a turbo setup on the supercharger setup, don't want to pay $275 for Procharger's "race" BOV, thanks?
87Aerocoupe is offline
Old 03-27-2015, 02:27 PM
mzgp5x's Avatar
Re: BOV question
Yes, they are a large price. I purchased (2) Bosch alum BOV, or, Bypass valves. I run two with an F1a Procharger. I run my MAF next to the air filter, so, I call them a bypass since the discharge must be re-introduced to the intake cycle (after the MAF).
I did have to re-cal the Bosch valve(s) springs for a 18 psi trigger point (zero vac assist). I paid $103 dollar over the inter_tubes. Got some new compression springs from Enco and cut them to calibrate for the 18psi.
I did an excel sheet to calculate the spring rate. Measured the force/ deflection rate and cut coils to match needed spring rate.
It can be done! B.
mzgp5x is offline
Old 04-12-2015, 12:25 AM
Re: BOV question
Thanks I got the Ebay XSPower 50mm BOV.
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
30thZ4C
Wheels and Tires
01-29-2015 06:03 PM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
Quick Reply: BOV question
