Blower Cam ideas on 383 build -14psi boost
Old 08-17-2013, 08:27 PM
97superchgedz28's Avatar
I'm doing a 383 build on my 97z28 that has a procharger psc1.. planning on running pulley for 14psi boost. My heads I plan on getting them ported most likely, if not looking into assembled aftermarket heads.
What blower cam minimum and maximum specs based on my set up do you think I should be looking into?
97superchgedz28 is offline
Old 08-18-2013, 12:03 PM
Re: Blower Cam ideas on 383 build -14psi boost
I should mention it is Street and Strip car. Once I figure out which cam, I'm going to figure out my Head set up
Old 08-19-2013, 06:03 PM
97WS6SCharged's Avatar
You're doing it backwards. Figure out the heads and have the cam ground to suit.
97WS6SCharged is offline
Old 08-21-2013, 03:46 PM
ill talk to the machine shop about my port job on my heads then ill get back to the cam..thx!
Old 08-22-2013, 02:46 AM
Before you commit to a head porter ask to see samples of their work and talk to people who have used them before. Some local guys have been working heads for years and can do magic and some just go crazy with a metal bit and call the end result a port.
Old 08-28-2013, 10:31 PM
CALL911's Avatar
Chris is correct in his logic. You could have hand ported stock heads, and a big cam won't be as benefitial as a more mild cam. Then again, if you are getting a large set of aftermarket heads and having them ported, then you have more options and probably could do a massive cam like I have in my D1SC car.
CALL911 is offline
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
transam_388
03-15-2015 11:53 AM
Quick Reply: Blower Cam ideas on 383 build -14psi boost
