Is an adjustable FPR requied on boosted applications?
Old 02-21-2015, 02:02 PM
87Aerocoupe's Avatar
As the title states I'm having a new all forged LT1 built and I'll be adding forced induction once the new engine is broken in and dynoed. Anyway I'm adding a DW300 (340 lph) intank pump and hotwire kit and the Speed Inc braided fuel lines from the hard lines to regulator and I'm wondering if I should install an Aeromotive or other afpr or is that a waste of money and time, thanks?
87Aerocoupe is offline
Old 02-23-2015, 01:22 PM
Purple Poncho's Avatar
Re: Is an adjustable FPR requied on boosted applications?
In it a waste? Depends on how much money you have. The stock regulator is 1:1 ratio and will do the job.
Purple Poncho is offline
Old 02-25-2015, 03:04 PM
mzgp5x's Avatar
I've tried two (2) AeroMotive FPRegs. The type that mount on the fuel rail. Both failed. So... I modded a Gen 1 single plane intake on a 383 LT1 with a parallel fuel delivery config. Used a remote Aeromotive Fuel Reg with boost ref and fuel bypass return to the fuel tank. I adjusted the reg to 43 to 45 psi. I have had much better luck with the larger regulator.
mzgp5x is offline
Old 02-25-2015, 05:18 PM
David94TA's Avatar
I have a 255 intank pump with a Kenne Bell Boost-a-pump and the stock regulator was not enough. I would run out of fuel at 5000+rpm. Changed to an adjustable FPR, bumped the fuel pressure up and it now works fine.
5-11-15 Edit: In the interest of providing accurate information, I wanted to edit my response. While changing to an adjustable FPR seemed to solve my problems at the time, I recently discovered that it was probably just a coincidence and the problem I was having was the result of something else. Sorry if I mislead anyone.
David94TA is offline
Old 02-27-2015, 12:20 AM
97WS6SCharged's Avatar
Sounds more like a problem with the injectors than the regulator.
OP unless you're pushing a large volume of fuel with bigger lines an aftermarket regulator is a waste of money. The stock regulator is capable of controlling all the fuel pressure/volume the stock lines can deliver.
97WS6SCharged is offline
Old 03-19-2015, 11:01 AM
Thanks guys I am getting a D1sc kit to go with my new all forged 383 and the rest of the parts in my sig, and I'll be adding a FMIC instead of the twins that come with the kit anyway will this be capable of making 700-750 rwhp? That's my target rwhp also what size injectors will I need 80#?
Old 03-20-2015, 01:23 AM
80's should work but you might want to tweak the pressure up a tad. I ran my 83's at 60 psi (plus boost reference) without issue.
G-BODYT56
01-14-2022 11:14 PM
RUENUF
03-13-2016 03:37 PM
93 RedBird
11-15-2015 08:24 AM
SEOJustin
09-24-2015 04:39 PM
95craz28
11
09-12-2015 07:47 AM
Quick Reply: Is an adjustable FPR requied on boosted applications?
