in 95 camaro lt1 w air buildup
i started this build a couple years ago but havent had much time to work on it. getting back into it now that that i have some more time.
pass side header, moslty done still needs the colector welded. i might take it to my friends house as its a pita to weld up the collector with the tig
dirver side same story as the pass side.
3" drivers down pipe
my ****ty intercooler welds and new hood latch. still working on the saftey catch. i plan on running 2 pipes out of the top pf the intercooler to the throttle body. i will have to notch and box the rad support to do this.
new aluminum fan monts. i had to lower the fans to fit the dual 3" down pipes. i also had to lower the swaybar 2" but it should still be higher than the k member..
right now its stock probaly under 5lbs.. i have another engine that will be built mid summer. probably try to get 3mo out of the stocker hopefully i dont pop it. doesnt really matter if i do pop it just would be a bit of a waste as its a low k motor.
my new engine will be a 383.
heads i have ported stockers that made the numbers in sig.
je 31cc dish pistons
eagle forged 3.75
eagle 5.7 H beams (probably get upgraded bolts)
eagle 4 bolt mains
i have arp head bolts may get studs
probably get some high z 79lb injectors and twin intake pumps
eagle forged 3.75
eagle 4 bolt mains
