671 Blown LT1, looks sweet!!! One question though.
Im wanting to do this with a small single carb blower & seeing how im all ready running a carb setup the only question I have is about the bolt pattern...What did this guy have to do to mate the blower manifold to the LT1 heads..How different is the bolt pattern from the LT1 heads and the old school heads? Go hear to read all about the only 671 blown LT1 I have ever seen..
http://users.senet.com.au/~tims/WebPage.html
Re: 671 Blown LT1, looks sweet!!! One question though.
It's hard to tell in the picture, but I bet he's using old-style heads with the conventional intake manifold bolt pattern. It's not too hard to modify them to work with the LTx cooling system.
Right, but it also looks like the intake manifold bolt that's visible is perpendicular to the gasket surface. The LTx is pointed more upward than that.
Trust me, its all LT1, Go here and check out his site with pics and build diary.
http://aussie-t.150m.com/motor1.html
Take a close look at the intake manifold bolt hole locations, namely the middle two.
Now, look at the middle two bolt holes in this LTX head:
http://www.flatlanderracing.com/afr-sbc210lt4.html
Here's the two styles side-by-side:
http://www.macmaster.on.ca/sbgm.htm
It may be an LT1 block, but there's something funny going on with his heads. They are NOT OEM production LTX heads because they do not have the correct intake manifold bolt pattern and angle.
Mike
Yeah, I can tell you whats screwy. He had the middle four bolt holes filled and new ones drilled for the old style manifold to bolt on. Thats what you have to do to bolt a blower onto a LT1.
I think your wrong. I say Exact same angle and JUST the center holes are different. Nothing like a hack job arguing with mechanical engineer. can you show me proof?
Mike
