Go Back   CamaroZ28.Com Message Board > Community > F-body Lounge
Sign in using an external account
Register Forgot Password?
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 02-06-2012, 10:55 PM   #1
Thoughts on sound deadening material
I am about to redo the interior in my camaro and the option arose of whether or not to get "mass backing" on the carpet.
Mass Back Carpet - Massback auto carpet - OEM Auto Carpet
Thoughts on this?
Or perhaps another product like dynamat?
Thanks!
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1995 Z28 M6 - LE2 H/C
Larsv8 is offline   Reply With Quote
Old 02-06-2012, 11:35 PM   #2
Premium Member
JP95ZM6's Avatar
Re: Thoughts on sound deadening material
I would rather put any damping material directly on the metal, so it is adhesive bonded and can add mechanical damping to the noise source. I suspect the results would be much better this way, but I have no data or references to back that up. Dynamat is great, but expensive.
If cost is a concern: I used a roll of premium Ice Guard roofing material in my Saab and had great results on horizontal surfaces, pretty good results on vertical. I just had a door skin off, and a little bit of the vertical had pulled away, so I can't recommend it for vertical surfaces. In the tire well, mostly horizontal, it's holding up perfectly after a couple of years. Almost $100 for a roll, REALLY sticky adhesive, and more than enough for a car even with multiple layers in some areas. I don't remember the brand, but it doesn't have much smell if any. Came from Lowes or HD.
__________________
95 Z28 M6, 417RWHP on Mustang, LE2/LE3, VRE Compstar/Mahle 383 shortblock, Pacesetter LTs, 58mm TB, Promag 1.6, LT4 ED timing set, 37# inj., TRE 255 lph pump, Street Twin. Home intake porting, Vector Motorsports tune. Best 12.006 @ 117 on F1 GS/D3s.
(Also Z71 Tahoe, Saab 9-2X Aero, XCSP 600, KTM 300EXC, Street-legal R1 go kart )
JP95ZM6 is offline   Reply With Quote
Old 02-07-2012, 07:44 AM   #3
CatsTasteGood's Avatar
Send a message via AIM to CatsTasteGood
What do you want to do? Do you want to control vibration or block noise? Dynamat is to control vibration which can create noise. If you want to block it you want to use Mass Loaded Vinyl (MLV).
I used some of this in my Z because that car screams when driving over concrete. 4 ft. x 25 ft. Flooring Acoustical Underlayment-DB448X25IBX at The Home Depot
It isn't as thick as a lot of the stuff on the market but it is easier to get and doesn't weigh as much.
If you really want to make the car sound proof you put dynamat (or similar) on each panel, a layer of foam, then the MLV.
CatsTasteGood is offline   Reply With Quote
Old 02-07-2012, 08:56 AM   #4
jy211's Avatar
__________________
My Toys
1955 150 Sedan, 1956 210 Sedan, 1968 RS Camaro
jy211 is offline   Reply With Quote
Old 02-07-2012, 09:13 AM   #5
Tokuzumi's Avatar
The corvette guys swear by Frost King stick on duct insulation. It's a little more than 1/8" thick, and is about $20/roll, and covers about 15 sq ft.
Shop Frost King Foam Duct Insulation at Lowes.com
__________________
Just your basic bolt-ons, and a loudmouth...exhaust
Tokuzumi is offline   Reply With Quote
Old 02-07-2012, 10:14 AM   #6
mdenz3's Avatar
Send a message via AIM to mdenz3
I think it is heavy and belongs in the trash.
__________________
-Mike D-
Quote:
Originally Posted by EKO View Post
AADD: Automotive Attention Deficit Disorder
Quote:
Originally Posted by notstock4long View Post
Holy **** you are stupid.
mdenz3 is offline   Reply With Quote
Old 02-07-2012, 10:37 AM   #7
Send a message via AIM to Sparkz28ss Send a message via Yahoo to Sparkz28ss
Quote:
This...
But if you need something try Sound Deadener Products FatMat Dynamat Xtreme Alternative or www.edeadsounddeadening.com fatmat is great stuff and cost less the dynamat...edead smells funny to me but I know a lot of people that use it and love it
__________________
07 TBSS 3SS 357rwhp/374rwtq
00.5 RSV Millie..140hp and 335lbs
99 LS1 SS #133 466rwhp/540rwtq 11.61@124mph
94 LT1 Z28 355ci ATI p600b FMIC chiller,N2O..F1?
86 C10 ....hopeless
Sparkz28ss is offline   Reply With Quote
Old 02-07-2012, 10:57 AM   #8
Blue89Bird's Avatar
Send a message via AIM to Blue89Bird Send a message via Yahoo to Blue89Bird
Quote:
Originally Posted by jy211 View Post
That's what I'm going to be using on my 68.
__________________
Jason
2004 CTS-V Kooks Long Tubes, Corsa Exhaust, K&N FIPK, BMR T/A's and Ground Control coil overs 375rwhp, 1996 Jeep Cherokee, 1972 4-4-2 Convertible,1968 Camaro
Blue89Bird is offline   Reply With Quote
Old 02-07-2012, 01:26 PM   #9
Well, all I know is that with the current stock setup, it gets really hot around the transmission. Vibrations don't really bother me, but I'd like a quiet comfortable ride if the windows are up.
Is it worth the money to go these routes, or just a waste of time?
__________________
Old 02-07-2012, 01:40 PM   #10
Tokuzumi's Avatar
Everyone I've read about that has done this has enjoyed the end result. I plan on wrapping the inside of my firebird in sound deadening material (foil lined) once it's no longer my DD.
__________________
Old 02-07-2012, 02:56 PM   #11
KrisH's Avatar
Send a message via AIM to KrisH
I do most of my cars with QuietRIDE. It's a really well-designed kit that's made specifically for your car. They send you a kit that has a thick padding that goes over a layer of Dynamat. The padding's all cut to fit the car perfectly (in most cases) and I can honestly say it makes a huge difference. They usually include a headliner kit too that helps a lot. The roof of my Mustang was super tinny when you tapped on it, but now it sounds like it's made of thick plastic...if that makes any sense. It's good stuff though.
QuietRide Solutions is their site I believe.
Edit: I didn't know this forum turns URLS into links automatically and renames them now...pretty sweet.
KrisH is offline   Reply With Quote
Old 02-07-2012, 07:15 PM   #12
Premium Member
JP95ZM6's Avatar
That is kind of a misstatement of the issue. Noise is vibration, and when the noise is transmitted through a panel, reducing panel vibration reduces the noise accordingly. Believe me, adding the heavy damping material to metal panels kills noise quite well!
__________________
Old 02-07-2012, 09:39 PM   #13
CaliChevyLover's Avatar
Just threw out the camaro's nasty old carpet, got some light rust to fix, thinking about just bed lining the floors
__________________
Quote:
Originally Posted by fuzzyblupenguins
I Fill up my mouth and then swallow. never taste it
Quote:
Originally Posted by fuzzyblupenguins View Post
YES! have yourself a 3 way
1989 S-10 Blazer 4.3L 4x4 Auto
1986 Camaro IROC-Z28 5.0L 2x4 Auto
CaliChevyLover is offline   Reply With Quote
Old 02-08-2012, 08:10 AM   #14
Premium Member
Z28Roxy's Avatar
Send a message via AIM to Z28Roxy Send a message via Yahoo to Z28Roxy
I used fatmat in mine
__________________
1995 Patriot Red Camaro Z28 Lunati/Wiseco Forged 383, CC 218/230, Trickflow heads, 1.6 RR
CAI, Pacesetter LTs, TDs xpipe/borla XR1s, Dana S60, BMR rear susp/kmember, 1.25" drop, Mez HD EWP.
Red 1997 Trans Am A4 Hooker Catback
Z28Roxy is offline   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2011 CamaroZ28.Com. All rights reserved.
