How much does it cost to tune-up an LT1???? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 02-17-2004, 03:02 AM   #1
How much would it cost to get it tuned up and where would I get that done?
MrCamZ is offline   Reply With Quote
Old 02-17-2004, 03:17 AM   #2
Re: How much does it cost to tune-up an LT1????
Quote:
HERE would be a good start.
j/k man I have no clue. Local track test/tune
Import_Eating_Z is offline   Reply With Quote
Old 02-17-2004, 06:50 AM   #3
Re: Re: How much does it cost to tune-up an LT1????
Over $6000 for some aluminum piece of trash with 320hp? For that kind of money he could go to www.gmpartsdirect.com and get a big block with nearly 500hp for $6600.
Dan Oldham is offline   Reply With Quote
Old 02-17-2004, 07:44 AM   #4
Quote:
Originally posted by robvas
Plugs, wires, fuel filter, air filter, oil change....
What else can you do?
All those parts are real cheap at Autozone but you will get hosed on the plugs if you don't do them yourself
Got that right! The first time I had my plugs changed, I was expecting to pay about $120. I got the bill and it was nearly $350! That's when I decided to do them myself, despite the hassle I wanted to save myself.
Old 02-17-2004, 08:30 AM   #5
jawzforlife's Avatar
Quote:
$350
Its times like this, that I'm happy I do all my own work. I just tuned up the truck last week (with my brother's discount at the parts store )
jawzforlife is offline   Reply With Quote
Old 02-17-2004, 09:12 AM   #6
Type_O_Negative_1320's Avatar
Plugs: $48 if you use Delco platinums, or $12 for NGK TR-55s.
Wires: $40(?) for a cheap OEM set, or $80-$90 for a good set (recommended)
Fuel filter: $9
PCV valve: $5
Air filter: $15(?) for a paper filter, or $40 for a K&N replacement
Oil change: $20-$30 for oil, $5 for a filter
You could also do a transmission flush/fill (if automatic), coolant system flush/fill, power steering fluid flush/fill, etc. You can do everything yourself...like everyone else mentioned, it'll be a lot cheaper that way.
Type_O_Negative_1320 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG dbusch22 Forced Induction 6 10-31-2016 11:09 AM
LT1 into a 3rd gen InfernalVortex LT1 Based Engine Tech 3 01-17-2015 09:35 AM
New Member / Help with cooling AlaskaZ28 LT1 Based Engine Tech 4 12-16-2014 07:24 PM
New Member introduction/a bit of help AlaskaZ28 New Member Introduction 2 12-10-2014 02:39 PM
new temp sensor that is faulty??? AlaskaZ28 LT1 Based Engine Tech 1 12-10-2014 02:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
