How long does it take to drain a 40 gal water heater? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 10-21-2008, 05:42 PM   #1
Mikes 1994 z28's Avatar
Im in the process of replacing my water heater. I've opened up all the hot water spouts in the house and opened the drain on the water heater. This was about 45mins ago and water is still coming out... cept not hot anymore. I've closed the valve on the cold water pipe at the top of the heater so there shouldn't be any new water going into the tank.
Mikes 1994 z28 is offline   Reply With Quote
Old 10-21-2008, 05:57 PM   #2
I cannot remember the exact time it took to drain mine, but it did seem like forever. If you have disconnected all sources of water, it will eventually run dry.
matLT1 is offline   Reply With Quote
Old 10-21-2008, 06:15 PM   #3
97QuasarBlue3.8's Avatar
That sounds like a long time. Check the valve and make sure it's actually off for the water feed into the heater. Especially if now it's running cold but was really hot.
97QuasarBlue3.8 is offline   Reply With Quote
Old 10-21-2008, 06:23 PM   #4
It should not output cold water if the supply valve is closed. It will refill itself if it is able to, and that sounds like what you've got going on, just that the incoming water is not getting the chance to warm up, but is coming out your faucets. Something is amiss. . . .
TDS-70 is offline   Reply With Quote
Old 10-21-2008, 06:25 PM   #5
I think the valve maybe broken or not fully closing. I had to put a channel lock on it just to turn it, it was so hard to screw. I turned off the main valve just now so we'll see if that does the trick.
Old 10-21-2008, 06:40 PM   #6
You should have a pressure relief valve with a downtube attached. Open that valve as well.
97 WS6 T/A Conv is offline   Reply With Quote
Old 10-21-2008, 06:41 PM   #7
bombebomb's Avatar
45 minutes to drain 40 gallons = less then a gallon per minute. Safe to say something is feeding it.
bombebomb is offline   Reply With Quote
Old 10-21-2008, 06:42 PM   #8
Shoot a hole in the bottm of it with the largest firearm you have availibe.
mdenz3 is offline   Reply With Quote
Old 10-21-2008, 06:51 PM   #9
I changed the 50 gal at my gf's house on saturday. I got a bit impatient waiting for it to drain so at around 1/2 empty I closed the spicket, threw my arms around it and carried it out.
mako350Z28 is offline   Reply With Quote
Old 10-21-2008, 07:45 PM   #10
Quote:
can you beat up the bear though?
6spdpewterZ is offline   Reply With Quote
Old 10-21-2008, 10:04 PM   #11
bombebomb's Avatar
Quote:
I chose yes.
Old 10-21-2008, 11:51 PM   #12
I used to drain my hot water tank twice a year. (Typically during the daylight savings/standard time changes). I figure what the heck. I had to go into the crawl space and adjust the timer. Might as well flush the system.
Yes, it takes an eternity to drain 40 gallons. 45 minutes sounded about right. At least 30 minutes and then some.
The water will get cooler as you drain it. When the electric element is off (breaker turned off), you have a combination of not heating water + emptying hot water. Once the level seeps below the elements, you're not getting any residual heat off the coils.
It also depends how far you're sending the drain water. In my case it would empty out a hose about 2 feet long and down a bit, and then exit into the soil for the sump pump to pick it up. If you're draining it 30 feet away and level ground, it's going to take a while.
Is the spigot for draining it open all the way?
Gord's Green Z28 is offline   Reply With Quote
Old 10-21-2008, 11:52 PM   #13
Chevycobb's Avatar
so...how long did it take?
Chevycobb is offline   Reply With Quote
Old 10-22-2008, 12:07 AM   #14
JP95ZM6's Avatar
Quote:
That's still too slow.
DIY Instant Water Heater Drainage
Yes, many of you probably guessed that was coming.
JP95ZM6 is offline   Reply With Quote
Old 10-22-2008, 12:13 AM   #15
The first thing I thought of was Torricelli's Law, but I'm not sure if that applies, is there a pump anywhere in the system or is it strictly gravity?
25gal x 8lbs per gallon + weight of the heater =
jerminator96 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
New girl with new car and new problems Magenta_Hearts New Member Introduction 4 03-25-2015 11:24 AM
"Drove 2000 SS through flash flood and now I'm paranoid" question jasonduaine LS1 Based Engine Tech 3 03-07-2015 10:44 AM
It's COLD. Get WARM. Save 10%. Heated Seat Kits on sale @ PFYC-PartsForYourCar PFYC Supporting Vendor Group Purchases and Sales 0 01-23-2015 02:13 PM
Coolant drain and fill directions? Sandersen511 General 1967-2002 F-Body Tech 1 01-13-2015 04:49 PM
Heater Hose replacement pologreen97z LT1 Based Engine Tech 0 12-02-2014 11:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
