How to get antifreeze smell out of carpet (heater core leaked)? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 02-23-2006, 09:14 AM   #1
RealDealZ28's Avatar
My '95 Z blew the heater core last week. I knew what had happened, and I managed to catch most of the antifreeze before it leaked onto my carpet, however, a small bit of it ran down into the passenger footwell. Well, I've cleaned and cleaned, and there's still a very small section that won't dry. I've already used water, and I run my heater wide open continuously to no avail.
What can I do to dry up this stuff, and more importantly, how in the world can I get rid of the nasty smell? It seriously makes me not want to drive the car because it stinks so bad. Please, some ideas, because Febreze auto spray ain't doing jack!
RealDealZ28 is offline   Reply With Quote
Old 02-23-2006, 12:17 PM   #2
Z28Nut's Avatar
Re: How to get antifreeze smell out of carpet (heater core leaked)?
Pee on it. It won't smell like anti-freeze any more
Actually it's probably soaked the insulation under the carpet. Try to pull the section free and soak up as much under the insulation as you can then CAREFULLY dry the section of insulation and carpet with a hair dryer. Once it's completely dry the smell should be gone.
Z28Nut is offline   Reply With Quote
Old 02-23-2006, 01:03 PM   #3
Quote:
Originally Posted by robvas
Replace the carpet?
Where's the best place to buy carpet? I've heard http://www.gmpartsdirect.com takes forever to ship, and I really hate living with the smell.
One more question: If I do decide to pull up the passenger-side carpet and dry everything, how do the kickpanels come loose?
Old 02-23-2006, 05:05 PM   #4
Buy a Bissel Little Green Pro Heat steam cleaner. It's small and designed for steam cleaning car carpets.
Gord's Green Z28 is offline   Reply With Quote
Old 02-23-2006, 05:09 PM   #5
Blue89Bird's Avatar
I used a wet dry vac and pulled the carpet up, sucked all of the excess out of the padding, then the carpet, and febreezed it and was good to go. There was a lot too.
Blue89Bird is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Help Countryboychevy General 1967-2002 F-Body Tech 3 06-13-2015 03:49 PM
1996 Z28 Lt1 HELP!! Leakage alex5366 General 1967-2002 F-Body Tech 4 02-17-2015 11:43 PM
heater core flush kksi LT1 Based Engine Tech 2 02-17-2015 11:41 PM
Electronic Heater Core???? Black93lt1 General 1967-2002 F-Body Tech 7 11-21-2014 08:30 PM
cloth/carpet vinnyxgunz Show and Shine / Paint and Body Care 4 03-17-2002 09:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
