Re: How do you adjust a metal storefront door?
Ok, it is on a Pemco continuous hinge. You have one of the following problems:
1) The door subframe is bent or has moved from it's original position. You can put a level on the door frame and see if it is out of level.
2) The door itself has sagged. I think this is the most likely case, if the door is using 1" thick glass. Use a small angle square in one of the corners to see if this has happened.
__________________
ΜΟΛΩΝ ΛΑΒΕ
06 GTO, CGM, A4 - 13.51@104.88 bone stock
94 Z28 A4, LT4 Hotcam
72 Nova - OLD SCHOOL hot rod
