Ever wonder what the underground gas tanks look like? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 03-05-2011, 07:10 PM   #1
Slappy3243's Avatar
Cool Ever wonder what the underground gas tanks look like?
They are rebuilding two gas stations nearby. I drive by these places daily and it seems like a pretty big job. Anyway, I caught a picture of the tanks before they were to be placed underground. The pictures don't really do them justice. They were absolutely enormous. I thought it is pretty cool.
Slappy3243 is offline   Reply With Quote
Old 03-05-2011, 07:16 PM   #2
CaliChevyLover's Avatar
Re: Ever wonder what the underground gas tanks look like?
So when prices shoot up overnight, it's because the gas already sitting in those tanks became magically more expensive?
No, I don't complain when the price goes down, just curious how the system works.
CaliChevyLover is offline   Reply With Quote
Old 03-05-2011, 07:19 PM   #3
Looks like its "ribbed". Probably expensive like the gas itself.....
iroc7 is offline   Reply With Quote
Old 03-05-2011, 07:54 PM   #4
Slappy3243's Avatar
I don't understand that either. The gas they have in the tanks is already paid for, so it should take some time for the more expensive gas to reach the station yet the prices go up over night. Now when the price of oil goes down, it takes months for prices to drop a dime or two
But that is not the point of this thread If you look in the third picture, there is another tank on a seperate truck. I am assuming they have a tank for each grade of gas although there were only two tanks there at the time.
Old 03-05-2011, 07:56 PM   #5
Sorry if I derailed it. Just a thought that popped into my head. Shouldve used the random thought thread.
Old 03-05-2011, 08:10 PM   #6
JP95ZM6's Avatar
I believe they use one for lowest grade (87), one for highest (93) and blend for the middle ones.
JP95ZM6 is offline   Reply With Quote
Old 03-05-2011, 08:16 PM   #7
ReNxWar's Avatar
The gas in the tanks isn't already paid for. Gas is "leased" by the day, and its sold at the cost of the gas by that day. So lets say gas is 3$ at 9am on Monday, the gas station would charge 3.15$ on Monday. The gas supplier would call on Tuesday and say gas went down to 2.40$ that day. The gas station will keep gas at 3.15$. (More or less.)
That above situation happened during Katrina when I worked at a service station. The gas supplier called and told us what price to set it at, even though during the entire disaster actual gasoline prices didn't rise. It was done to try and lower demand, they called it. I called it price gouging
ReNxWar is offline   Reply With Quote
Old 03-05-2011, 08:20 PM   #8
Thank you for the explanation!
Old 03-05-2011, 08:36 PM   #9
Quote:
For your pleasure. We might as well enjoy is while we're being ****ed up the ***
JJEXP is offline   Reply With Quote
Old 03-06-2011, 12:12 AM   #10
Slappy3243's Avatar
It's cool. Sometimes the board can get a little heated over gasoline and all hell breaks loose
Old 03-06-2011, 08:56 AM   #11
94Camaro_Z_28's Avatar
Quote:
How would that work here? Our 89 and 91 have 10% Ethanol, 87 does not.
94Camaro_Z_28 is offline   Reply With Quote
Old 03-06-2011, 09:04 AM   #12
MustangEater82's Avatar
Quote:
so they say...
MustangEater82 is offline   Reply With Quote
Old 03-06-2011, 10:03 AM   #13
notstock4long's Avatar
With those tie-downs, it looks like a gigantic resistor.
notstock4long is offline   Reply With Quote
Old 03-06-2011, 10:25 AM   #14
JP95ZM6's Avatar
In that case, I suspect they have one tank of 87, and one tank of a ethanol, or ethanol-blended premium, which they add in the proper proportion to get the intended octane. Pure Ethanol is like 108 RON. In that case, though, the 89 and 91 could not both be exactly E10.
Old 03-06-2011, 12:42 PM   #15
cool.
93transam1234 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
94 Z28 Automatic transmission - engine stall - No codes present Nayr LT1 Based Engine Tech 3 09-05-2015 07:12 PM
[Georgia] Early 95 v6 3.4 liter camaro Pwilson59 South Atlantic 1 09-03-2015 09:47 PM
97 LT1 EVAP Purge Solenoid Pressure Relief Plug Blowing Out 350350 Fuel and Ignition 14 08-11-2015 01:03 PM
95 Camaro Z28 Fuel Tank Pressure Alibi Fuel and Ignition 1 08-01-2015 08:50 PM
1996 fuel injectors clogged Anon Fuel and Ignition 4 07-23-2015 01:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
