Car won't crank-security light on. - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 03-08-2012, 05:45 PM   #1
95 LTI Formula auto. I tried to start and no crank but the security light was on, i have never seen it on before. I had running bout an hour ago and no problem. What do i need to do. Danny Mc
Danny McAdams is offline   Reply With Quote
Old 03-08-2012, 05:46 PM   #2
UnknownWarrior's Avatar
Re: Car won't crank-security light on.
Quote:
problem with the VATS system, you either need a new key, do a chip bypass or need a new vats computer
UnknownWarrior is offline   Reply With Quote
Old 03-08-2012, 07:17 PM   #3
greenformula94's Avatar
In order for you to drive it right now, you gotta unlock the car, get in, put the key in the ignition and sit for 5-10 minutes without touching a single button in the car.
I had this happen numerous times on a buick i had, a sunfire, and i think my firebird did it once.
it can be caused by a dirty key, bad key, or the chip is getting old.
but if you sit in there with the key forward and dont touch anything it starts right up.
greenformula94 is offline   Reply With Quote
Old 03-08-2012, 07:41 PM   #4
jloshotz's Avatar
When this happened on my previous z, it just started happening more frequently over time. VERY annoying, because it usually happens when you are running late, and it FORCES you to wait lol. I was able to get lucky...I shot some contact cleaner, and then some keyboard duster (both with a straw) in the ignition cylinder. Then I cleaned the key pellet on both sides with a pencil eraser. Worked like a champ, my problem went away. Like I said, lucky lol. Might want to give it a shot though before spending money or time attempting to bypass. Good luck.
jloshotz is offline   Reply With Quote
Old 03-08-2012, 07:58 PM   #5
ImportKILLER's Avatar
Ignition cylinder.
Had to replace mine a few years ago.
ImportKILLER is offline   Reply With Quote
Old 03-08-2012, 08:35 PM   #6
94Camaro_Z_28's Avatar
I wipe the key on my shirt. Tada.
94Camaro_Z_28 is offline   Reply With Quote
Old 03-08-2012, 09:02 PM   #7
jloshotz's Avatar
Quote:
Originally Posted by 94camaro_z_28 View Post
i wipe the key on my shirt. Tada.
lol!
Old 03-08-2012, 09:40 PM   #8
knta4dnu's Avatar
If you don't have spray contact cleaner, flatten a Q-Tip with pliers, wet it with rubbing alcohol and you can reach the contacts in the cylinder.
knta4dnu is offline   Reply With Quote
Old 03-08-2012, 10:11 PM   #9
Thanks for the advice guys. Danny Mc
Old 03-09-2012, 09:27 AM   #10
had same problem on my old '94 formula. you could wait (like others said) or you could disconnect the negative battery terminal and touch it to the positive terminal which is basically like letting it sit for a while without the battery connected. everything is reset.
another awkward thing is is that I had VATS disabled and also had a remote start on the car. it would start all the time with the remote start but as soon as I went to use the key I would get the damned security light and it wouldnt turn over. now im wondering if, based on the other responses in this thread, it was the key.
Zigroid is offline   Reply With Quote
Old 03-09-2012, 10:35 AM   #11
You can get them made at your local hardware store and specify you want no chip.
they wont have the gm head logo tho
Old 03-10-2012, 08:54 PM   #12
Red89GTA's Avatar
Uh, oh. sounds expensive, you should go to the dealer.
or did you get it fixed already?
Red89GTA is offline   Reply With Quote
Old 03-11-2012, 12:38 PM   #13
Malice 1's Avatar
Whenever my 99 camaro used to do this, I would just unhook the battery and hook it back up. It took less than 5 minutes, and it started up every time after that.
It didn't do it to me to often though..
Malice 1 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
94 Z28 issues bfmv13trivium General 1967-2002 F-Body Tech 9 01-14-2015 10:57 AM
Brake pedal on Floor Red97LT1 Suspension, Chassis, and Brakes 9 12-17-2014 07:13 PM
Shot power steering system after brief heat up? ro2207 LT1 Based Engine Tech 14 12-04-2014 07:18 PM
New! Total Blackout (or colors/CF) Decal Kit for 2010-13 Camaro @PFYC-PartsForYourCar PFYC Supporting Vendor Group Purchases and Sales 0 12-04-2014 12:56 PM
clicking sound icm replaced USAirman93 General 1967-2002 F-Body Tech 4 11-24-2014 04:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
