50:1 vs 40:1 gas:oil ratio; are they interchangable? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 03-29-2006, 11:09 AM   #1
Threxx's Avatar
I'm looking at getting an Echo blower, but it's a 2-cycle and specifies a 50:1 gas/oil mix ratio. The two other pieces of outdoor equipment that I have that are 2-stroke both are 40:1. I'd prefer to go all 4-stroke to be honest, but if I must get a 2-stroke blower (since all the good 4-stroke models are like 3 times as expensive) I don't want to have to have to keep ANOTHER seperate gas mix can with 50:1 mix in addition to my existing 40:1 mix can.
I'm sure it'll run with 40:1 mix, but will it make any noticable impact on the longevity or power output of the blower?
Threxx is offline   Reply With Quote
Old 03-29-2006, 11:22 AM   #2
Re: 50:1 vs 40:1 gas:oil ratio; are they interchangable?
Are you serious
These guys will work on everything. Less oil = overheating, more = blue smoke. For brake-in period, more oil is better.
valter is offline   Reply With Quote
Old 03-29-2006, 11:23 AM   #3
Super Moderator
JakeRobb's Avatar
Blower? As in leaf blower?
I'm no expert, but I think you'll see a power loss and a more-frequently-fouled spark plug if you use the 40:1 mix in a blower designed for 50:1. (In addition to the extra blue smoke you'll get from burning the extra oil)
Now, we're talking about using 2.5% oil in a blower designed for 2%, so it's not like the difference is going to be noticeable. You seem to concern yourself with longevity and reliability more than the average joe, so maybe you should keep looking (or resolve to keep that extra can around).
Say, what happened to the Seal of Approval?
JakeRobb is offline   Reply With Quote
Old 03-29-2006, 11:28 AM   #4
Threxx's Avatar
Quote:
It got stale. I may bring it back sometime. For now Calvin's parents need to keep an eye on robvas so he doesn't get in any trouble.
Old 03-29-2006, 11:42 AM   #5
nitrojunky's Avatar
Quote:
good luck with that
nitrojunky is offline   Reply With Quote
Old 03-29-2006, 11:56 AM   #6
More oil is not necessarily good in a 2-stroke. In a 4-stroke (that doesnt burn oil directly [except in LS1 applications!]) you want everything nice and oily for protection of metallic surfaces. In a 2-stroke the oil is mixed with the gas and burned, and it needs to be the proper proportions of oil/gas/air to make an efficient cycle. Anything extra fouls plugs (as mentioned) and lessens power. For break-in periods it is standard to use more oil as well as building up the motor RPM in correct increments, but not general use.
Dave 96TA is offline   Reply With Quote
Old 03-29-2006, 12:04 PM   #7
DougsfastZ's Avatar
Your going to need to get another gas can. I blew a head gasket on my Toro with the wrong oil/gas mixture, it was a higher then 50:1. The problem was the gas can held more then a gallon of fuel and I didn't realize it. Make sure when you go to the gas station to mark with a marker where a gallon is when filling. Also jot down the ratio so you know which can is which.
Doug D
DougsfastZ is offline   Reply With Quote
Old 03-29-2006, 12:06 PM   #8
Doug - you sprayed that Toro, don't lie.
Old 03-29-2006, 12:09 PM   #9
West South Central Moderator / Special Guest
I can't imagine it causing a problem. Mix both of them at 45:1 and call it a day. I bet that is well within the tolerance for mixing for both manufactures.
JordonMusser is offline   Reply With Quote
Old 03-29-2006, 12:11 PM   #10
DougsfastZ's Avatar
Quote:
It happens The Briggs has a 30 shot on it right now, 1/4 acre only takes 15 minutes To bad I have to run at a full sprint.
Doug D
Old 03-29-2006, 12:40 PM   #11
Z28x's Avatar
Quote:
LOL...thats what I was thinking. If it was being used 3 hours a day every day, then I'd make sure to use the right mixture
Z28x is offline   Reply With Quote
Old 03-29-2006, 12:41 PM   #12
Heck I ran my 110 and 93 mix with 50:1 in a leaf blower. I wouldnt go less oil but I really dont see were a little more would hurt. I dont think I have ever fouled a plug on a 2 stroke lawn equipment motor either, I think they have higher tolerances than say my dirt bike. The first mix is what I use in the dirt bike and I dont liek to let it sit for too long so it goes in a jug for the lawn equipment.
dave
oscar80 is offline   Reply With Quote
Old 03-29-2006, 12:57 PM   #13
I wouldn't worry about it. That little amount of oil won't cause damage in the 2 stroke. Can you imagine some of the people that buy these things? I bet half of them don't know how to start them let alone mix the gas. I would be daring enough to say that you could go easily 10+ or - the wrong way and still be fine. You would be surprised what a 2 stroke can take for abuse!
hsyr is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Lt1 parts..cam/rockers..etc 13qtr Parts For Sale 24 10-28-2016 08:11 PM
1994 Camaro Z-28, 850hp, Supercharged 396 w/NOS, 9.5@143 RUENUF Cars For Sale 6 03-13-2016 03:37 PM
383 lt1 swap Z Power LT1 Based Engine Tech 8 09-19-2015 11:19 PM
94 Z28 Automatic transmission - engine stall - No codes present Nayr LT1 Based Engine Tech 3 09-05-2015 06:12 PM
AeroForce Interceptor: The Do-Everything Gauge, ships FREE @ PFYC-PartsForYourCar PFYC Supporting Vendor Group Purchases and Sales 0 08-07-2015 01:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
