2000 S10 4.3L runs rough, unplug MAF runs much better? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 06-17-2006, 09:15 PM   #1
DropZ
Guest
Posts: n/a
I'm working on a buddy's S10, it runs terribly in the lower RPM range and decent in the 3k-5.5k range. We changed plugs and wires, but it didn't help. As a guess I unplugged the MAF and it was a 1000% improvement. If the check engine light wasn't on I would've thought the truck was running perfect. Does this indicate a bad MAF, for certain? He definitely has bad O2 sensors, is it possible those are causing this problem?
Also posting this on S10forums.com but thought it may be general knowledge for some in here.
Old 06-17-2006, 09:19 PM   #2
deputydough's Avatar
Re: 2000 S10 4.3L runs rough, unplug MAF runs much better?
if you unplug the maf it will throw a light. try cleaning the maf before replacing it. if it has been a while for the o2's then replace them.
deputydough is offline   Reply With Quote
Old 06-17-2006, 09:22 PM   #3
Drive XR7's Avatar
Clean the MAF first. Rough idle and sluggishness is a very common indicator of a dirty MAF. Use cue-tips and windex, but be VERY CAREFUL because the wires are delicate.
Drive XR7 is offline   Reply With Quote
Old 06-17-2006, 11:01 PM   #4
CrabhartZ28's Avatar
Do they use the same MAF as LS1's? If so i've got one you could use.
the O2 sensors and MAF both being bad would seriously make it run like ****.
CrabhartZ28 is offline   Reply With Quote
Old 06-17-2006, 11:03 PM   #5
get some electronics cleaner, use a cotton swab, and clean it out
z28marine is offline   Reply With Quote
Old 06-18-2006, 12:13 AM   #6
Clean the M.A.F. Also head on over to S-Seriesforum.com Although, you may not get a response asap as most of the guys are at the S-10 Nats in St. Louis someone should lurking around there though.
Brandon_Lutz is offline   Reply With Quote
Old 06-18-2006, 12:44 AM   #7
The CPI spider is going to ****. Or, if lucky, just a fuel pressure regulator...
Those are the same symptoms my dad's 97 C1500 w/350 had. Shop wanted to replace every sensor the CE codes tossed at them, then add in $800 for potentially roasted cats (from running really rich) and then the spider as well.
$500ish for the revised unit.
If you go google group search chevrolet poppet problems (no quotes), you should get plenty of reference to this and the silent recall in 2003 for this issue...maybe a stealership will foot at least part of the bill for the part.
O2's rarely cause problems...they usually are indicative of problems.
Glad to help.
AlfredB18 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
PSC Motorsports Racing Power Steering Pump LT1 HectorM52 Parts For Sale 4 06-23-2016 09:42 PM
new camshaft and lifts 1775.Z28 LT1 Based Engine Tech 7 01-11-2015 11:51 AM
Do PCMs fail? AlaskaZ28 LT1 Based Engine Tech 9 01-01-2015 01:30 PM
[Michigan] Clean 96 Caprice Classic for sale BIGCOWL-IMP Midwest 0 11-21-2014 10:40 AM
FS: Memphis ST1000D amp Krab Car Audio and Electronics 1 08-05-2002 01:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
