Whole new exhaust system for my 97 SS
Old 07-01-2013, 07:58 PM
kozmosis's Avatar
When I bought the car, the CAT'S were cut out and replaced with flexible tubing and in the process they also cut the header pipes. So, if I am starting from scratch and will keep the similar setup. (Y pipe to dual exhaust) So would you go with short or long headers, ceramic, stainless or other? Any other recommendations? Current setup has plenty of power and actually a bit too loud at times. Not my first Z, but it is the first one that is just a toy.
97 ss - 6 speed manual, t-tops and leather.
kozmosis is offline
Old 11-27-2013, 01:59 PM
87Aerocoupe's Avatar
Re: Whole new exhaust system for my 97 SS
I'm in the same boat I just brought a 97 SS m6 with completely rusted out exhaust including the Pacesetter coated long tubes. I ordered the ebay 1 3/4" stainless longtubes and Y pipe but I also have a complete 3" stainless true dual setup with Magnaflow mufflers for another 4th gen that I never installed so I'm going to install it on the new SS and never have to worry again because the stainless steel will never rust.
87Aerocoupe is offline
Old 11-28-2013, 06:29 AM
kozmosis's Avatar
Let me know how things go for you. I still have not made any purchases. Did you purchase the obx headers from ebay?
kozmosis is offline
Old 12-02-2013, 08:19 PM
No these look like Pacesetter knock offs Google 93-97 Z28 stainless steel headers and you should get the ebay link. They were 350 with the y pipe and shipping.
Old 12-02-2013, 09:38 PM
kozmosis's Avatar
Thanks, I found them. I can get a system from the headers all the way back in stainless steel for under $800. Let me know how your install goes.
kozmosis is offline
Old 06-02-2014, 06:04 PM
mzgp5x's Avatar
I have a 97 SS MM6. I had SLP shorts. Went to Pacesetter Lg-tubes. Long tubes much better. A lot of re-wire with the long tubes. Also did my own Y and a Mufflex 3 1/2" cat back. No cats yet. Maybe later. Used Stage 8 fasteners bolted to AFR 190 heads. They really work. Previously I had a lot f fasteners come loose on the SLP shorts. Happy modding. B.
mzgp5x is offline
Old 01-26-2015, 06:45 PM
kozmosis's Avatar
Does anyone know of any fake cats that I can get over a 3" stainless steel ory. The cars cats were cut out when I purchased the car and got it inspected at one place no problem. I had put classic plates on the car to get around the emissions test. Put a new stainless works system on the car from the long tube headers all the way back. Now I took it in for inspection and they won't even look at it as soon as they see the car does not have cats. They are calling it a safety issue, but was told they would pass it if had something that look like a cat (visual inspection) . What a pain in the ***. I don't want to cut anything, just take a cat that would be hinged so you can slip it right on. Someone could make a fortune if they are not already available. If they are, who has them.
kozmosis is offline
Old 01-27-2015, 08:46 AM
Why not just install dual high flow cats? They are not going to produce a noticeable loss of performance on a stock engine. I built an 800HP nitrous motor, flanged the header collectors and Y-pipe so I could run dual 3" CarSound cats on the street and pass tailpipe emissions, and drop them out and install Borla XR1 mufflers when I went to the track and used leaded fuel.
Injuneer is offline
F'n1996Z28SS
08-23-2023 11:19 PM
alex5366
Exhaust System
02-24-2015 09:12 AM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
Quick Reply: Whole new exhaust system for my 97 SS
