Long tube headers, what length o2 extensions?
Just like the title say. I'm getting ready for my new exhaust system and I want to know what length o2 extensions do I need? Headers are full length, don't plan on having a rear o2 sensor, fronts only
Re: Long tube headers, what length o2 extensions?
Sometimes it takes longer than 24 hrs to get a reply- this forum seems to have lost quite a bit of traffic.
When I put my long tubes in I was able to re-route the one side so only had to extend the one side- which was about 8-10".
12" extensions should be long enough for you I would think.
I believe the correct answer is 18" for one side and 12" for the other. I believe I did the longer size on both. A lot easier to zip tie up some slack than wait on another part because you were short.
edit: looks like I'm a little off. I searched my email and it looks like I ordered 2 24" o2 extensions from autowiringsolutions on eBay. Here's the exact product I bought, of course it was a couple bucks cheaper in 2010.
http://www.ebay.com/itm/O2-OXYGEN-SE...-/250913043615
O2 Oxygen Sensor Extension 24'' LT1 Corvette 4 Pin Flat | eBay
Much is appreciated!
Not if you good with a soldering iron
I may or may not. Depends on how much I enjoy fabbing up my exhaust system. By the time I get around to hooking up my o2s I may not care.
~Nathan
~Nathan
If you are just wanting to solder something together, the Pacesetter LTs come with some wire to extend your o2's.
I'll end this topic with the correct information.
You need a 24" and a 12"
The drivers side uses the 24" and the passenger is a 12"
There you go!
There you go!
07-04-2005 05:00 PM
