Header Recommendations
Re: Header Recommendations
If your car is a DD at all, I'd go for some sort of stainless LTs, the cheapest ones are LPP. For roughly the price of Pacesetter ceramics (if not a bit less) you can pick up a set of stainless LPP LTs, your best bet is to check ebay or craigslist, as the site is currently out of stock. You could try to contact them though, maybe you could get a set on back order or something if you're willing to wait.
If money is not to much of an issue you could go with Stainless works or for a few hundred more Kooks. Both have a Y pipe that will bolt right in to your new Cat back. Good luck and thanks for serving in the Air Force. I assume you are anyway since it says Andrews AFB. I was at a little place called Davidsonville for 6 years. It was my first duty station in 84. It is part of Andrews AFB.
Depends on your situation.
Will ground clearance be an issue? (Is car lowered or do you plan on lowering it?)
What's your budget?
Do you have emission requirements?
Do you plan on running a catted or offroad y-pipe?
What's your budget?
94Z28LS1toLT1
04-07-2015 05:37 AM
jasonduaine
Exhaust System
03-20-2015 09:00 AM
