Car chemistry exhaust pipe muffler inserts, good, bad...?
Old 09-28-2011, 07:33 PM
bluz28's Avatar
I thinking of going with two of their 2 disc insert, right after the headers to mainly get ride of some 1000-1500rpm drone and possibly quiet it down some. Will using these inserts cause enough restriction to noticeably hurt me in HP/TQ ?
Anyway I'd like to hear your opinion, especially you've used them before.
http://www.jegs.com/images/photos/10...176-3DI25R.jpg
bluz28 is offline
Old 10-06-2011, 10:40 PM
mzgp5x's Avatar
Re: Car chemistry exhaust pipe muffler inserts, good, bad...?
I use a 3 1/2" 3 disc in a Mufflex system before the axle kick. I also had resonance @ 2k rpm. Much noise, and, potential problem with the law. I also installed the 7/8 cap in the center section. It really helped alot. With no cap, still too much noise. But, with a FI app, I also had to install a QTP electric bypass to get flow when dialing up the power. Had to modify the QTP due to excess pressure bending the valve plate on the non-supported side. Now, not a problem after my mod, but, most of the fastners in the QTP had to be replaced and enlarged + red lock-tite.
I also run a Spintech chambered muffler. Open flow mufflers did not work with FI app.
B.
mzgp5x is offline
MadMav
02-06-2015 11:02 PM
ModdedNerd
01-01-2015 10:56 AM
BIGCOWL-IMP
12-19-2014 06:59 AM
USAirman93
11-24-2014 03:37 PM
CobraEatr
07-29-2002 11:46 AM
Quick Reply: Car chemistry exhaust pipe muffler inserts, good, bad...?
