whats the width of a 96 camaro rear end??
Old 04-16-2004, 10:58 PM
96a4z28's Avatar
does anyone know?
im parting out my camaro and a guy wants to know if it will fit on his 56 chevy without narrowing the rear end...
thanks guys
96a4z28 is offline
Old 04-17-2004, 07:16 AM
Capn Pete's Avatar
Where do you need the measurements taken from? Axle hub to axle hub? End of the tubes? I've got a diff out in my garage I can measure.............I'll get some #'s for you later today.
Capn Pete is offline
Old 04-17-2004, 05:27 PM
96a4z28's Avatar
Smile
ok thanks alot man
96a4z28 is offline
Old 04-18-2004, 12:49 PM
Capn Pete's Avatar
Okay, I took measurements in a couple places cause I didn't know where you'd want them from.
From the outside face of the axle hub to the opposite axle hub, I got 5' 4-3/4".
From the outside face of the backing plate to the opposite backing plate, I got 5' 1".
From center to center of the spring perches, I got 3' 4".
If you need more specific info, let me know. Hope that helps.
Old 04-18-2004, 04:20 PM
96a4z28's Avatar
im sorry man, i meant like the width from disc to disc. a guy with a 58 chevy said it couldnt be no longer than 58 inches in order to get onto his car and he didnt wanna have to narrow it.
96a4z28 is offline
Old 04-18-2004, 08:44 PM
Capn Pete's Avatar
This diff I have doesn't have brakes on it, so I can't give you disc to disc, but what I gave you should be close. But if you look at the measurements I got (5' 1" from backing plate to backing plate), that's 61", and I don't think the discs would be any further inward than the backing plates since the calipers bolt on to them, so I'd say that disc-to-disc probably wouldn't be less than 61", and definitely not less than 58"? If that's the case, then the rear end may not work for that guy?
Old 04-18-2004, 08:57 PM
96a4z28's Avatar
Cool
heyyy thanks alot man..apreciate that
96a4z28 is offline
oldschool
02-09-2016 09:21 PM
ChrisFrez
12-28-2014 02:25 PM
ModdedNerd
12-25-2014 05:51 PM
CaRParts102
12-06-2014 08:45 AM
Quick Reply: whats the width of a 96 camaro rear end??
