What is a used 94 Z28 rear end worth?? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 04-14-2005, 08:40 AM   #1
Cool ZR's Avatar
Question What is a used 94 Z28 rear end worth??
Hey,
I have a chance to buy a used rearend out of a burnt car that I am buying. I want the gears only for my car when I convert from A4 to M6. It has about 125k miles on it. What would be fair or would I be better to just buy a gear set?
Cool ZR is offline   Reply With Quote
Old 04-14-2005, 09:12 AM   #2
94formulabz's Avatar
Re: What is a used 94 Z28 rear end worth??
Just get some 3.73s or 4.10s. think of all the m6 guys on here discussing gear swaps, the stock gears are a lil steep.
The only time 3.42s make sense is for a swap into an auto with 2.73s on an extreme budget.
If you are on an extrememly tight budget(you have the wrong hobby), and its out of a car that is very close to stock and still want it: $100-150 at most.
Make sure it has the same ABS setup that you currently have. Do a search, its discussed all the time in drivetrain.
A couple nice things i will say about a factory setup is that the gears won't whine. Swapping the whole rear is very easy(especially if it comes with the brake brackets) and requires no special tools. Its a good oppertunity to paint it up nice and black and make it look pretty if you are 100% certain that the car will never require a 12 bolt or 9".
good luck,
Brent
94formulabz is offline   Reply With Quote
Old 04-14-2005, 10:01 AM   #3
Cool ZR's Avatar
Thanks for the info on that.
I talked to the guy and he wants about $350 for the entire rear end. I will just buy a new set of gears for the car. I have the budget for it, I just thought this would be simplier if the price was cheap enough. I was also thinking I could have it blasted and painted up before I installed it. I plan on having about 400 hp when I am finished, just enought to get me into trouble.
I am going to do a search later on the zexel conversion and see what the consensus is on that.
Reply
Thread Thread Starter Forum Replies Last Post
LT1 Perf Parts: Ported heads, rockers, BBK TB etc... oldschool Parts For Sale 16 02-09-2016 10:21 PM
1984 Chevrolet Camaro Collector Car Cars For Sale 0 01-05-2015 11:58 AM
Free Rear end/Axles/Driveshaft nodnarb481 Middle Atlantic 0 01-02-2015 12:43 AM
spring question ModdedNerd Suspension, Chassis, and Brakes 1 12-25-2014 06:51 PM
Poor gas mileage...?? The Seer Classic Engine Tech 2 11-26-2014 06:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
