trans, again
Old 06-29-2015, 06:57 PM
jackpawt883's Avatar
trans, again
welp i blew it again, this time no movement in any gears, full of kinda burnt smelling fluid, think the pump went? and any suggestions on replacement units? need a new high hp rated one, not the 300 dollar craigslist special lol
jackpawt883 is offline
Old 06-29-2015, 07:03 PM
Re: trans, again
Stock 4L60E should easily handle what's shown in your sigature. Sounds like you got a poor quality rebuild.
Injuneer is offline
Old 06-29-2015, 07:11 PM
Re: trans, again
i didnt even get a rebuild, i got a matching trans off craigslist, installed, and went. money was short and i needed the car, but financially i'm a little free'd up and id like to get some more oomph out of the motor, and i have some plans on how to do that, i just need some suggestions on rebuild kits, sides i want this to be the last time i pull this car's trans
Old 06-30-2015, 07:40 AM
Re: trans, again
Sent a PM with some info on rebuilds.
Injuneer is offline
Old 07-02-2015, 05:41 AM
FirstYrLS1Z's Avatar
Re: trans, again
to OP,sig shows 2200 convertor,why only a 2200 convertor ? leaving a lot of performance on the table !
FirstYrLS1Z is offline
Old 07-02-2015, 12:31 PM
Re: trans, again
i got told by my friends dad (who has been building camaro's and other race application gm's) that with my build a 2200 would be about what i want for streetability, but i think i might want to go a little higher this time, especially since im going to be beefing up the motor
Old 07-02-2015, 12:45 PM
Re: trans, again
"a little higher this time" ? you should've already been in the 3200-3600 range !
Instead of starting at 2200 where high torque application causes a sort of engagement to the drivetrain and having to climb/accelerate thru all that low horsepower part of the curve, a 'higher' stall will start more into the 'meatier' part of the curve. You're not wasting time(1/4 mile ET) climbing thru it. And that applies to every gear.
force10
08-10-2015 08:30 AM
ricks95TA
07-23-2015 12:59 AM
jackpawt883
07-20-2015 06:32 PM
dolfan324
07-17-2015 10:34 PM
Fastbird93
07-11-2015 04:37 PM
Quick Reply: trans, again
