Throughout bearing
Throughout bearing
Re: Throwout Bearing - How hard is it to change?
HELP!!!!!!!!!! I just installed a chrome molly F/W kevlar clutch and Presser plate with T/B, and here is my problem The clutch fork came off during the sliding of the trans back in I have tried to put the fork back on the t/o bearing with out having to pull the trans back out, I have tried pushing praying and hitting it but it will not go back on! Someone please help me What am I not doing right.
__________________
1994 camaro, LT-1. .30 over stock bottom end with arp studs, arp rod bolts complete bal, stock alum heads ported and polished, valve guides,presser tested, oversize valve 2.02 1.60, 5 angle valve job with 344x562 seals, .525 springs, lt4 hot cam, 160deg stat, fresh air intake, 36mm throttle body, MSD.......
__________________
