Technical Question???
Old 05-01-2016, 07:25 PM
Stephen68's Avatar
I have looked all over but cant find the answer...On my 95 TA with factory 4L60E, i just replaced the rear universal joint....Do i need to use all 4 circlips or just 2? If i am supposed to use all 4, does anyone have a pic of where the 2 with the saddle straps goes at? Thanks!
Stephen68 is offline
Old 05-02-2016, 07:44 AM
Re: Technical Question???
The pinion yoke does not require clips because it has little tabs to keep the bearing caps from going anywhere.
shoebox is offline
Old 05-02-2016, 12:48 PM
Stephen68's Avatar
Thank you Fred, would you have or know of a pic showing the tabs...I cant see anything on my pinion yoke....
Old 05-02-2016, 09:52 PM
I'm not Fred, but I just looked at a pic I have of an LS rear yoke and there are no tabs. I know there are on older rears. Anyway, the cups wont go anywhere after you install the driveshaft and put the straps on.
shoebox is offline
Thirim
Parts Wanted
03-29-2016 10:44 AM
Stephen68
03-17-2016 06:10 PM
Thirim
19
03-13-2016 01:35 PM
drptop70ss
02-24-2016 05:09 PM
wpjdoc
02-17-2016 03:37 PM
Quick Reply: Technical Question???
